bellett.net
https://bellett.net/forums/
Bolt on four pot brakes?
https://bellett.net/forums/viewtopic.php?f=35&t=939
Author:  JT191 [ Fri Jun 11, 2010 6:44 pm ]
Post subject:  Bolt on four pot brakes?
Author:  bellett65 [ Sat Jun 12, 2010 7:37 am ]
Post subject:  Re: Bolt on four pot brakes?
I will be the devils advocate here. They could not be used in Aus. even if you could get kits for them. Tghe rules here are quite clear. You have to use at least 3 of the original mounting holes. Apart from the welded in fill? only 2 mounting holes used. Where 4 were used on the original. Whether it was drum backing plate or caliper mounting bracket it does not matter. Brake and safety go hand in hand. :ugeek:
Author:  JT191 [ Sat Jun 12, 2010 1:46 pm ]
bellett65 wrote:
I will be the devils advocate here. They could not be used in Aus. even if you could get kits for them. The rules here are quite clear. You have to use at least 3 of the original mounting holes. Apart from the welded in fill? only 2 mounting holes used. Where 4 were used on the original. Whether it was drum backing plate or caliper mounting bracket it does not matter. Brake and safety go hand in hand. :ugeek:
For GT? It should be just two bolts holding the original caliper, right? If it were a conversion for a car which came with drums, that sounds like a problem. But would I have to add two more bolts if it only came with two just so that I could upgrade calipers?
Author:  bellett65 [ Mon Jun 14, 2010 12:26 am ]
As per piccy
Author:  JT191 [ Mon Jun 14, 2010 2:13 am ]
Author:  RobSA [ Mon Jun 14, 2010 7:27 am ]
Author:  JT191 [ Mon Jun 14, 2010 3:20 pm ]
This is what I am thinking:
Author:  RobSA [ Tue Jun 15, 2010 12:55 pm ]
Sounds pretty good.
Author:  JT191 [ Tue Jun 15, 2010 2:27 pm ]
RobSA wrote:
Sounds pretty good.
That's the smallest Wilwood vented disk is 10 1/4. That extra 1/2 inch diameter is probably going to cause a lot of clearance problems. With the 9.9 inch Nissan rotor, 13 inch steel wheels might fit. And they are $75 USD, almost twice as much as the Nissans. The Nissan rotor bolt pattern is more similar to the Bellett, so the hat or adapter will be more compact and simpler. Using this extremely large caliper on a small rotor causes clearance issues between the inside edge of the caliper and the hub.
Author:  JT191 [ Tue Jun 15, 2010 8:11 pm ]
So, I have bad news.
Author:  PR91 [ Thu Jun 17, 2010 12:02 pm ]
have a look here:
viewtopic.php?f=13&t=709
Author:  JT191 [ Thu Jun 17, 2010 3:36 pm ]
I'm new to this obscure corner of the already obscure Isuzu world, but not unable to operate a internet search engine. I've not found much of anything in the English speaking world as far as people selling performance or even replacement parts for Belletts. Who's selling brake kits or brake kit parts?
Author:  RobSA [ Sat Jun 19, 2010 7:06 am ]
Thanks Brett.
Thanks for the info on the different stub axles, can add that to the bank of Bellett knowledge :D
Author:  JT191 [ Sat Jun 19, 2010 4:51 pm ]
Author:  PR91 [ Sun Jun 20, 2010 10:34 am ]
no probs rob.
Author:  PR91 [ Sun Jun 20, 2010 10:46 am ]
exactly JT.
Author:  JT191 [ Wed Jun 30, 2010 4:36 pm ]
Author:  JT191 [ Tue Mar 01, 2011 2:25 am ]
Page 1 of 1 All times are UTC
http://www.phpbb.com/
