bellett.net
http://bellett.net/forums/
starter motor brushes
http://bellett.net/forums/viewtopic.php?f=39&t=3536
Author:  TASSMAN [ Tue Feb 06, 2018 5:58 am ]
Post subject:  starter motor brushes
can anybody help with starter motor brushes.Supplier ,Brand ,Number or maybe what else fits.CHEERS
Author:  CQGT [ Sun Feb 18, 2018 9:55 am ]
Post subject:  Re: starter motor brushes
Hi Tassman.
I am assuming that you are restoring the car and you may have the starter motor on the bench.
I can give you the genuine part number but will be of no use as most of the non genuine manufacturers
in the early days, 60's & 70's,did not use or obtain the genuine part number to have as a cross reference
to their own part number.
The best thing to do is to take the starter to an auto electrician and get them to test it and repair.
Quiet a few of the Japan manufacturers basically used one of two major auto electrical companies to
supply components to their requirements. These being Hitachi or Mitsubishi. Getting brushes, I don't think,
will be a problem as these manufacturers will produce a brush to suit a multitude of starters and getting non
genuine will not be a problem for the auto electrician.
Author:  GerryBellettGT [ Mon Feb 19, 2018 9:19 am ]
:) Well said Dave,I took the starter off the Tassie Devil,local auto elec,sorted through a box of bits and had brushes to suit,been told gemini starter will fit,Gerry
Author:  TASSMAN [ Wed Feb 21, 2018 8:45 pm ]
Dave and Gerry,thanks for info re starter brushes.Took to local auto elect,measured and ordered.3 days and new brushes .from O.E.X. no:B.R.X.71223 Hitachi.Thanks again.
Page 1 of 1 All times are UTC
http://www.phpbb.com/
