Author |
Bellett_EST
Joined: Tue Oct 10, 2017 8:41 am Posts: 75 Location: Tallinn, Estonia
Hi! I have a 1966 Bellet sedan, but have some problems with spare parts. My car is the only Bellet in Estonia, so it's not easy to find spares. First and main problem is rear lights, one of mine is broken. If anyone has a spare pair of 1963-1966 rear lights, I would be iterested. Waiting for offers mainly from Europe (Finland, Sweden) or Australia, but if shipping to Estonia is OK, then other regions would be OK too. My location is in Europe, but I have a contact person in Mackay, Queensland, so the shipping could be done through him. List of other spare parts needed, also waiting for offers: Mirrors (inside and outside) Windscreen washer tank Front lights (High beam) Reverse lights Blank keys
_________________ The only Bellett in Estonia
Fri Oct 13, 2017 9:29 am |
More photos of the car please and the broken taillight. ??what exactly do you need on the light the right. Hand side is ok
Fri Oct 13, 2017 11:47 pm |
Bellett_EST
I don't have pics of the broken left taillight at the moment. Right one has some cracks and it actually looks a bit worn too. On the pic it's wet, therefore looks OK. Left one is broken. If I could just replace the left one, it would be OK to get the car inspected, but for the better look, I would prefer the lights equally worn. Some pics on the car: And here is one of the broken key. It works, but needs to be replaced. Anyone has a blank key for 1960.-s Isuzu?
Sat Oct 14, 2017 12:51 pm |
Very nice car, better condition than mine
Sun Oct 15, 2017 10:39 am |
Bellett_EST
Thanks! The car actually looks better on pics than in real life. Fortunatly not much rust problems, but the paintjob has been done by drunk one-eyed sailor. Still have lot of work to do, as the car hasn't been on streets since last century. But I like that it's built really simple, no over-engineering. One stupid question came up today: Where is the turn signal relay located? Picture of the broken tail-light.
Sun Oct 15, 2017 8:15 pm |
hi thanks for the shots the yearly nationals are on and I guess by later next week all will be home I would suggest following this up there are some guys with bits ..cheers davo
Sun Oct 15, 2017 10:22 pm |
hi the washer tank is a plastic bag that clips on to the 2 hooks on the firewall it has a screw on cap and the lines come out of it its operated by a manual pump on the dash ,rare but avail the blinkers at the rear are avail in 2 lenses white and orange ,the rear vision mirror try farmer on here the indicator unit is under the dash .the lights are 2 and 3 prong pretty avail I have spares .... the rear taillights are avail well sort of I have spares .....see how you go ..cheers dave are you on facebook I can send pics ....
Mon Oct 16, 2017 10:00 am |
sorry the keys I have one spare ..................
Mon Oct 16, 2017 10:01 am |
Bellett_EST
I can be found in Facebook by the name Martti Suur.
I didn't quite understand your post about washer tank etc. I have the washer pump, but no tank.
What about the rear view mirror?
Mon Oct 16, 2017 10:10 am |
The plastic bag sits on the right side hooks into 2 angle hooks on the body. Maybe yours is on the left under the horn
Mon Oct 16, 2017 11:25 pm |
The key maybe it can be cut to suit??
Mon Oct 16, 2017 11:45 pm |
This is my set
Mon Oct 16, 2017 11:46 pm |
The headlights are originally Toshiba. 2. And 3 prong which one is not original the 2 or 3. Cheers dave
Mon Oct 16, 2017 11:53 pm |
There is no trim on the inside pillars do you want a photo and also the door handles face. Upwards. Otherwise the windows won't wind in the back especially I can take a photo. Cheers davo how'd you go with the headlights ?? Cheers dsve
Tue Oct 17, 2017 10:44 am |
Bellett_EST
BULLITT wrote: There is no trim on the inside pillars do you want a photo and also the door handles face. Upwards. Otherwise the windows won't wind in the back especially I can take a photo. Cheers davo how'd you go with the headlights ?? Cheers dsve OK, good to know there are not supposed to be any covers on B-pillars. I know the door handles should be upwards, I don't know why they are put like that on my car. I'll see about the key later today. I'm afraid your key has too deep cuts in it. Suppose I could use it, if I change the lock a bit (I don't know the english term, the moving parts that avoid turning the lock without correct key). I will see, what parts I can get from Finland, it would be easier and faster to get parts from there I suppose. But thanks for your help.
Tue Oct 17, 2017 10:56 am |
All good bit by bit. Inch by. Inch. Cheers davo
Tue Oct 17, 2017 11:15 am |
Bellett_EST
Got the turn signals today. The blinker relay needs to be replaced, but the switch works. Some wires in the front need to be fixed but that should be piece of cake.
Wiper drive is still stuck. Seems I need to take off the dashboard to get closer.
Main goal is to clean up the bottom ASAP, to give it some rust protection.
Tue Oct 17, 2017 8:12 pm |
Bellett_EST wrote: Got the turn signals today. The blinker relay needs to be replaced, but the switch works. Some wires in the front need to be fixed but that should be piece of cake.
Main goal is to clean up the bottom ASAP, to give it some rust protection. you should be able to remove the wiper motor from under the dash
Tue Oct 17, 2017 10:48 pm |
Bellett_EST
Glenn wrote: Bellett_EST wrote: Got the turn signals today. The blinker relay needs to be replaced, but the switch works. Some wires in the front need to be fixed but that should be piece of cake.
Main goal is to clean up the bottom ASAP, to give it some rust protection. you should be able to remove the wiper motor from under the dash The motor isn't a problem, but the drive rods are stuck.
Wed Oct 18, 2017 6:11 am |
a single circlip under the dash which fixes the wiper arms into the back end of the motor releases the wiper bars the 3 screws taken off will take out the motor I would take out the motor make sure the arms are turning its pretty easy I may have a diagram I will look tomorrow morning cheers dave one thing at a time
Wed Oct 18, 2017 10:23 am |
