View unanswered posts | View active topics It is currently Tue Apr 23, 2024 8:49 am
Reply to topic  [ 19 posts ]
Headlight Switches
Hi guys,
Does anyone have some spare pair? Mine have died so likely a worn contact...haven't had time over the last 6 weeks to whip them out to check (just can't drive after dusk)!
Duane
Mon Jul 29, 2013 9:13 am
Should be able to help there.
Had a look this morning and have got one. (untested) but moves freely enough
Mon Jul 29, 2013 9:25 am
Cheers Josh, PM me your details if you like and I'll give you a call. Otherwise, there's Facebook!
Tue Jul 30, 2013 6:27 am
Car(s): Roman Red 1965 Sedan, Mint 67 Sedan Auto, 1967 GT , 1.5x 1967 sedans, 1968 Deluxe Sedan, 1965 Wasp Ute (Resto project)
it may be a GT switch that Duane is needing??
I sure don't have one. may find a aftermarket one to suit
Tue Jul 30, 2013 11:08 am
Everything Im looking at says the main switches are the same, the only difference is the fog lamp toggle switch next to the heater controls
Tue Jul 30, 2013 12:22 pm
Yes, the main switches are the ones I'm after, same on 1500's and GT's.
Tue Jul 30, 2013 1:16 pm
may have one or 2 or 10 of those
:mrgreen: :mrgreen: :mrgreen: :mrgreen:
yeah
Wed Jul 31, 2013 2:32 am
Awesome, cheers 'oz'...if I can catch up with one of you guys this week, that'd be awesome. PM or Facebook me with price and movements this week if you like. :geek:
Wed Jul 31, 2013 8:37 am
down port Adelaide direction tomorrow morning for a funeral.
will go and dig about in the shed right now!
Wed Jul 31, 2013 11:08 am
Thanks to Oz and Josh for the switches guys.
Now..okay...obviously there must be some trick to this. The headlight switch is now unclipped, but I cannot get access to the loom to disconnect the switch itself...there are a lot of things that seem to unscrew and/or unclip in front of the switch to help with access, but none of them will actually unscrew or unclip. Before I start attacking 50 year old plastic parts with a screwdriver, can anyone tell me how do you get these bastards out?
Tue Aug 13, 2013 4:04 am
put switch back in, reach around behind it and unplug the 4 pin connector and then remove the switch with the now loose wiring and connector. May have to get on the floor and reach up behind the dash
fitting is reversed
Tue Aug 13, 2013 12:13 pm
Hmmm...that easy, eh? I've tried that and couldn't get it to budge (also unsure whether I had the right connector/loom). I'll give it another go and be more brutal this time. Cheers.
Tue Aug 13, 2013 11:21 pm
they can be real tight, Duane.
get a torch in there and keep wriggling. it will come apart.
easier for me, done it many times before
:D :D :D :D :D
Tue Aug 13, 2013 11:28 pm
:( Unfortunately, it's not so easy...the centre console needs to come out, but after undoing everything I could find, that won't budge either!
Wed Aug 14, 2013 1:18 pm
Eventually found the hidden screws beneath the console, but when I connected the new switch the problem was still there...gave up and sent it to an auto electrician...turned out to be the fuse box! Bead-blasted and replaced all the pins, good as new.
Thanks for the help guys...recon dizzy and alternator are next! Anyone have a spare of either?
Fri Apr 18, 2014 10:15 am
Duane
this will fit and just needs a small length of vacuum hose between the original metal line and the new hose connection.
worked a treat on my Auto Sedan!
http://www.ebay.com.au/itm/1974-1975-74 ... 24b&_uhb=1
Sat Apr 19, 2014 1:02 am
and the alternator...
try a quote for recon from Smith Bros Auto Electrics at Holden Hill as GTtoo had them do some work and was very pleased with the cost and the outcome!
approx $200 i reckon to have it done
Sat Apr 19, 2014 1:10 am
Cheers oz...Josh sent me a link to the dizzy guys also, many thanks...will hit the button on one of these. My centre bearing is stuffed, so hard to get the timing right.
Thanks for the tip re: alternator...I was considering buying another for recon so I could do a swap over, seeming as I need the car to drive daily, but just occurred to me my wife will not be studying second half of the year, so I will have the Fiesta and can afford to be without the Bellett for a few days. Do you remember when you visited and looked through my parts? There's an alternator amongst the bits I have here, but I remember you saying it wasn't Bellett...may do regardless?
Sat Apr 19, 2014 2:34 am
if its not original Bellett, then either the connections wont be correct or the fittings to the engine wont be.
either way its not worth bastardizing around with it.
better to get another and get it done. bound to be a few about my shed somewhere!
but i would not bother getting it done unless the bearings are noisy or the charging circuit is not working.
while it works, let it be.
Sat Apr 19, 2014 9:55 am
