Author |
Asroc66
Hi All Currently on eBay
Tue Mar 15, 2016 7:21 am |
$150 for a set of standard hubcaps...
I'm a millionaire.
Tue Mar 15, 2016 8:26 pm |
Pretty rich price for caps with dints and gutter rash. I'd pay that for mint one's but not one's that are banged up
Wed Mar 16, 2016 8:03 am |
As a point of interest for anyone considering the twin SU manifold (and it seems there are at least 2 people keen so far) It is for a 1500 iron head and suits H4 SU carbs as used on the 1950's MGA (HS4 SU carbs could be used but would need adapters as they mount on an angle) H6 SU's (or HS6 SU's) like those on the Triumph's or Datto's (180B or 1600) won't fit it, totally different bolt pattern. With that in mind you will also need to budget a minimum of $300-750 for used H4's (if you can find any that don't need rekitting - 2x H4 kits $275) or $1100-1500 for new ones. But have a crack at bidding on 'em if your really keen........ cause ya know I will (when is another one ever gonna come up??)
Wed Mar 16, 2016 11:31 am |
Stickman wrote: As a point of interest for anyone considering the twin SU manifold (and it seems there are at least 2 people keen so far) It is for a 1500 iron head and suits H4 SU carbs as used on the 1950's MGA (HS4 SU carbs could be used but would need adapters as they mount on an angle) H6 SU's (or HS6 SU's) like those on the Triumph's or Datto's (180B or 1600) won't fit it, totally different bolt pattern. With that in mind you will also need to budget a minimum of $300-750 for used H4's (if you can find any that don't need rekitting - 2x H4 kits $275) or $1100-1500 for new ones. But have a crack at bidding on 'em if your really keen........ cause ya know I will (when is another one ever gonna come up??) or use it to convert to EFI............
Wed Mar 16, 2016 9:36 pm |
Glenn wrote: or use it to convert to EFI............
Well there's a thought I didn't consider
Thu Mar 17, 2016 8:56 am |
toomanybelletts
Joined: Thu Nov 06, 2008 4:23 am Posts: 83 Location: Kilsyth , Melbourne
Car(s): see user name
Those manifolds were available short & long - I have both & use the longer ones on my rally car for more torque . The GT carbs fit straight on . - Craig
Thu Mar 17, 2016 11:33 pm |
I think the H4 SU's might be easier to track down but there's every chance others will already have them stashed away for that one day just incase. Here's ya chance boys and girls
Sat Mar 19, 2016 3:24 am |
Asroc66
Hi All (2) sets 1600cc pistons Standard and .020 oversize Should be circlips rather than press fit
Fri Mar 25, 2016 7:44 am |
