Gunna
This is the 2 door spare sports project.
The name 2000GTSS comes from: 2000GT (the standard GT Belletts are badged 1600GT) S (sports model) The second S (the spare sports that Glenn called it). We were going to add a small "i" to indicate fuel injection but the name is long enough already.
Picked up from Victoria in Feburary 2016 from Glenn P
First step is stripping for sandblasting.
Edit:
The plan is to fit the G200W 2 litre twin cam motor and 5 speed gearbox in that Glenn supplied with the car. The motor is in surprisingly complete condition.
I have a Motec M4 with opened logging and lambda, and a LCD dash. The plan is to fit that as well. The gps will give me speedo and other usefull (and useless) info. But more importantly I will be able to select up to 4 different running program's for various conditions, such as; Highway economy Learner mode Sports mode 400 metres Methanol tune Low grade fuel tune, And any other you can really think of.
File comment: Lots of ugly surface rust.
| Fri Mar 04, 2016 11:56 pm |
Gunna
Thx Glenn, I was worried about them
File comment: Lego tail lights.
| Sun Mar 06, 2016 2:51 am |
Gunna
Carbies might be missing but the manifold is there. Yahoo!!!
| Sun Mar 06, 2016 3:00 am |
Gunna
And what a dash!! In k's.
| Sun Mar 06, 2016 3:01 am |
Gunna
And in all of the bits was;
| Sun Mar 06, 2016 3:09 am |
Gunna wrote: Thx Glenn, I was worried about them the other tail light surround should be there also Dean ??
| Sun Mar 06, 2016 3:10 am |
Gunna
And even a flare hidden up under the steering wheel rhs
| Sun Mar 06, 2016 3:16 am |
Gunna
Glenn wrote: Gunna wrote: Thx Glenn, I was worried about them the other tail light surround should be there also Dean ??Nothing so far but I'll keep digging. Removing Fuel tank with holes - rusted bolt heads- 9 inch grinder
| Sun Mar 06, 2016 4:25 am |
Gunna
A small pile of 45 year old rust. Rhsr quarter.
| Sun Mar 06, 2016 4:31 am |
Gunna wrote: Glenn wrote: Gunna wrote: Thx Glenn, I was worried about them the other tail light surround should be there also Dean ??Nothing so far but I'll keep digging. Removing Fuel tank with holes - rusted bolt heads- 9 inch grinder  carefull with the tank, its the rare 46 litre one. (rare here that is)I may have another surround for the lights if you cant find one in there. I never opened up a lot of the stuff in the car! whats that badge ??
| Sun Mar 06, 2016 4:56 am |
Gunna wrote: And even a flare hidden up under the steering wheel rhs have a flare in mine also. Must be compulsory in Ja. Goodness knows if they actually work.
| Sun Mar 06, 2016 4:57 am |
Japanese yen $1 ????
| Sun Mar 06, 2016 6:19 am |
BULLITT wrote: Japanese yen $1 ???? not worth much then Dean !
| Sun Mar 06, 2016 7:08 am |
Gunna
Glenn wrote: BULLITT wrote: Japanese yen $1 ???? not worth much then Dean ! It came with a sports bellett,,,,,,,priceless.
| Sun Mar 06, 2016 9:11 am |
Gunna
Glenn wrote: Gunna wrote: Glenn wrote: Nothing so far but I'll keep digging. Removing Fuel tank with holes - rusted bolt heads- 9 inch grinder  carefull with the tank, its the rare 46 litre one. (rare here that is)I may have another surround for the lights if you cant find one in there. I never opened up a lot of the stuff in the car! whats that badge ?? I've heard about that 46ltr tank from somewhere. It's got some nasty rust holes in it and the drain plug has been pushed up. But if it's rare it's fixable. I was going to junk it as I had been given another standard tank from Peter A. Like you, I haven't dug thru everything yet but it is in one space. I'll ferret around once the shell is off to the sandblaster.
| Sun Mar 06, 2016 9:25 am |
Like you, I haven't dug thru everything yet but it is in one space. I'll ferret around once the shell is off to the sandblaster.[/quote]
the 46 Litre tank sits below the bottom edge of the rear valance panel by about 40mm . Std tank is not visible when viewed from rear
Extra 6 litres is well worthwhile
| Sun Mar 06, 2016 10:20 am |
Gunna
Glenn wrote: I've heard about that 46ltr tank from somewhere. It's got some nasty rust holes in it and the drain plug has been pushed up. But if it's rare it's fixable. I was going to junk it as I had been given another standard tank from Peter A.
Like you, I haven't dug thru everything yet but it is in one space. I'll ferret around once the shell is off to the sandblaster. the 46 Litre tank sits below the bottom edge of the rear valance panel by about 40mm . Std tank is not visible when viewed from rear
Extra 6 litres is well worthwhile[/quote]
| Tue Mar 08, 2016 11:34 pm |
Gunna
Front guards, boot, bonnet & doors off. Photo includes mad 11 year old with supposedly sore throat and couldn't go to school today.
File comment: Doors, guards, bonnet and boot off. 09/04/164
| Tue Mar 08, 2016 11:37 pm |
Gunna
And this is why we strip them down.
File comment: Lhs lower door pillar rust.
| Tue Mar 08, 2016 11:39 pm |
borer in the usual place ...plate time ??
| Wed Mar 09, 2016 6:15 am |
