View unanswered posts | View active topics It is currently Wed May 27, 2026 1:11 am
Reply to topic  [ 18 posts ]
Bolt on four pot brakes?
Fri Jun 11, 2010 6:44 pm
I will be the devils advocate here. They could not be used in Aus. even if you could get kits for them. Tghe rules here are quite clear. You have to use at least 3 of the original mounting holes. Apart from the welded in fill? only 2 mounting holes used. Where 4 were used on the original. Whether it was drum backing plate or caliper mounting bracket it does not matter. Brake and safety go hand in hand. :ugeek:
Sat Jun 12, 2010 7:37 am
bellett65 wrote:
I will be the devils advocate here. They could not be used in Aus. even if you could get kits for them. The rules here are quite clear. You have to use at least 3 of the original mounting holes. Apart from the welded in fill? only 2 mounting holes used. Where 4 were used on the original. Whether it was drum backing plate or caliper mounting bracket it does not matter. Brake and safety go hand in hand. :ugeek:
For GT? It should be just two bolts holding the original caliper, right? If it were a conversion for a car which came with drums, that sounds like a problem. But would I have to add two more bolts if it only came with two just so that I could upgrade calipers?
Sat Jun 12, 2010 1:46 pm
As per piccy
Mon Jun 14, 2010 12:26 am
Mon Jun 14, 2010 2:13 am
Mon Jun 14, 2010 7:27 am
This is what I am thinking:
Mon Jun 14, 2010 3:20 pm
Sounds pretty good.
Tue Jun 15, 2010 12:55 pm
RobSA wrote:
Sounds pretty good.
That's the smallest Wilwood vented disk is 10 1/4. That extra 1/2 inch diameter is probably going to cause a lot of clearance problems. With the 9.9 inch Nissan rotor, 13 inch steel wheels might fit. And they are $75 USD, almost twice as much as the Nissans. The Nissan rotor bolt pattern is more similar to the Bellett, so the hat or adapter will be more compact and simpler. Using this extremely large caliper on a small rotor causes clearance issues between the inside edge of the caliper and the hub.
Tue Jun 15, 2010 2:27 pm
So, I have bad news.
Tue Jun 15, 2010 8:11 pm
have a look here:
viewtopic.php?f=13&t=709
Thu Jun 17, 2010 12:02 pm
I'm new to this obscure corner of the already obscure Isuzu world, but not unable to operate a internet search engine. I've not found much of anything in the English speaking world as far as people selling performance or even replacement parts for Belletts. Who's selling brake kits or brake kit parts?
Thu Jun 17, 2010 3:36 pm
Thanks Brett.
Thanks for the info on the different stub axles, can add that to the bank of Bellett knowledge :D
Sat Jun 19, 2010 7:06 am
Sat Jun 19, 2010 4:51 pm
no probs rob.
Sun Jun 20, 2010 10:34 am
exactly JT.
Sun Jun 20, 2010 10:46 am
Wed Jun 30, 2010 4:36 pm
Tue Mar 01, 2011 2:25 am
