View unanswered posts | View active topics It is currently Thu Jun 04, 2026 10:48 pm
Reply to topic  [ 5 posts ]
Spring ratios
Hi All
Wondering what the ratio is for rear springs
By that I mean
If you lower rear springs by 1 inch does it lower the ride height by 2 inches?
Ie ratio 1:2
Mon Jul 06, 2015 8:07 am
Measure it.
Pull it apart.
Pull out the upper and lower spring rubbers.
Put it back together.
Measure it again and measure the rubber thickness.
Divide the difference in ride height by the rubber thickness.....
Theres your ratio.
I've always worked out my installed height and spring rate needed and had them made to suit.
Is exactly what the race car has.
Read your sway bar question too and replied.
Mon Jul 06, 2015 12:46 pm
Thanks PR91
on both accounts
Mon Jul 06, 2015 10:52 pm
In case anyone interested
Lower rear springs by 25mm translates to about 35-40mn ride height
In old language
1 inch lower springs drops ride height by 1 1/4 - 1 1/2 inches
Thu Jul 09, 2015 6:27 am
Always interested.
And thx again for sharing.
Dean
Thu Jul 09, 2015 8:38 am
