| Spring ratios https://bellett.net/forums/viewtopic.php?f=35&t=3084 |
Page 1 of 1 |
| Author: | Asroc66 [ Mon Jul 06, 2015 8:07 am ] |
| Post subject: | Spring ratios |
Hi All Wondering what the ratio is for rear springs By that I mean If you lower rear springs by 1 inch does it lower the ride height by 2 inches? Ie ratio 1:2 Thanks J |
| Author: | PR91 [ Mon Jul 06, 2015 12:46 pm ] |
| Post subject: | Re: Spring ratios |
Measure it. Pull it apart. Pull out the upper and lower spring rubbers. Put it back together. Measure it again and measure the rubber thickness. Divide the difference in ride height by the rubber thickness..... Theres your ratio. I've always worked out my installed height and spring rate needed and had them made to suit. Is exactly what the race car has. Read your sway bar question too and replied. |
| Author: | Asroc66 [ Mon Jul 06, 2015 10:52 pm ] |
Thanks PR91 on both accounts Cheers J |
| Author: | Asroc66 [ Thu Jul 09, 2015 6:27 am ] |
In case anyone interested Lower rear springs by 25mm translates to about 35-40mn ride height In old language 1 inch lower springs drops ride height by 1 1/4 - 1 1/2 inches Cheers J |
| Author: | Gunna [ Thu Jul 09, 2015 8:38 am ] |
Always interested. And thx again for sharing. Dean |
