FUEL FILTER RYCO ORIGINAL R 2224P
Post by BULLITT »
RANG RYCO TODAY NO LUCK ON ANY GENUINE R2224P ORIGINAL FUEL FILTER WENT TO SUPER CHEAP BOUGHT THE PLASTIC FUEL FILTER $2.99 HAD A LOOK AND THOUGHT GEEZ THATS CLOSE SO TOOK IT HOME CUT THE LID OF AND ITS VIRTUALLY A PERFECT MATCH UNSCREWED THE FILTER PUSHED IN THE NEW YOU BEAUT FROM SUPER CHEAP ...AND AWAY WE GO ....SO WENT BACK AND BOUGHT A SPARE ...HANG THE EXPENSE ....CHEERS DAVO
Re: FUEL FILTER RYCO ORIGINAL R 2224P
Post by PR91 »
part number davo?
then we can add it to the filter list in the "parts interchangability" section.
Post by BULLITT »
hi brett part no. SC4F BARCODE 9323129007028 CHEERS DAVO
Post by PR91 »
cheers mate.
have u run the car with it fitted?
let me know how it goes and i'll add it to the list.
Post by BULLITT »
NO I HAVNT YET IM OFF TO ALBURY TOMORROW I WILL FIRE IT UP NEXT WEEK CHEERS DAVO
Post by PR91 »
heard u were heading this way.... ;) ;)
65bellett
Car(s): 65 and 66 sedan
Post by 65bellett »
Get the camera out Davo we need some pics of your handy work.
Post by BULLITT »
HI MATE WILL BE OFF TOMORROW WILL TAKE SOME SHOTS WENT TO SUPERCHEAP TODAY BOUGHT ANTHER 2 UNITS ..IN CASE THEY BECOME SHORT ...WHO WANTS ONE ???? CHEERS DAVO
Post by BULLITT »
hi ..sorry for the delay on checking the filter ...have been pretty flat strap ...i have a question..??? i havnt fired up the car for some 4 mths and tank is near empty what fuel should in put in it ...i have the additive ? can you please advise me ...oh i know where to put it (the fuel that is ) cheers davo
BELLETT69
Car(s): BELLETT SEDANS X 3
Post by BELLETT69 »
Dave, I would personally use Premium Unleaded, I find that Mobil premium is the best for mine. Cheers Steve
CQGT
Post by CQGT »
Davo,
Interested to see how you got on with the filter. I used 1 of the Nissan filters in mine, but I could'nt get it to seal off. My cork gasket seal may be to hard. It has a shiney finish to it and also the filter may nor be sealing properly in the centre. With all the spares that I have, it was the best. I have some leftover cork material from when I made the rocker cover gasket. Will make a new 1. I have a new [R2224P] filter that the tin base plate fell off. 406 superglue fixed that. Test time next weekend.
I pressurized my fuel tank to do tests. You will need another person to give you a hand. This way you will pick up any leaks in your piping as well. Right up to the carby. I've had leaks at the banjo fitting on the filter and the fuel pump. Wet & dry on the sealing face of the filter,banjo fittings and the banjo bolts. New alloy washers. I use Hyundai sump plug washers. Right size,and not too hard like some of the copper washers on the market.
Post by BULLITT »
hi guys at last i got the car running and especially to check if the filter worked ..leaked etc .....took out the old one (tin) and pushed in the new plastic filter firmly put on the rubber seal tightened it all up started the car and watched ..ran the car ...no problems they work they are easy to get and easy to fit ...just cut the top of the new plastic filter and pull out the identical looking filter great stuff cheers davo supercheap autos .....if you cant get em let me know i will get some here
CQGT
Post by CQGT »
Davo,
I went and bought a filter on Saturday arvo. Sliced it open that night and removed element. It's uncanny how that filter is nearly the same as the original. Only difference that I found was the hole diameter. Put an extra 'o' ring to seal it off.
Won't be this weekend to fireup car. Looks like it might be next.
Here's hoping.
Post by BULLITT »
photos on today once downsized and posted cheers davo .......hey dave it doesnt leak cheers davo
Post by BULLITT »
here goes it works for me no leaks car ran for 10 mins cheers davo if you cant work it out email me
Post by Farmer »
Looks spot-on Davo, great work!
A cheap solution to the disappearing parts problem.
Post by mrflibbles »
anyone know what the filter crosses over to in ryco or another brand?
Its all good it says on the supercheap website it is a generic inline filter, i guess i will hack a couple of the filters up at work and see what falls out of them!
