| DOHC webber manifolds https://bellett.net/forums/viewtopic.php?f=36&t=2726 |
Page 1 of 1 |
| Author: | F3ARED [ Wed May 28, 2014 12:48 am ] |
| Post subject: | DOHC webber manifolds |
Hi guys, Have so far somewhat unsuccessfully tried to get photos of DOHC webber manifolds as per the ones that are being made through the forum. Is anyone able to assist with some pictures so i can set about seeing if they are suitable for my ITB conversion? Nick. |
| Author: | flying [ Thu May 29, 2014 9:40 am ] |
| Post subject: | Re: DOHC webber manifolds |
Hi Nick Found this website in Japan that sells the manifolds I will post the link for the twin can manifold which is on page 4 but if you look on page 3 it would appear that the g161 twin webers manifolds -- no sure http://www.microsofttranslator.com/bv.a ... 26page%3D2 Cheers Flying |
| Author: | flying [ Thu May 29, 2014 9:41 am ] |
Nick link is to page 3 look at page 4 OOPS |
| Author: | BULLITT [ Thu May 29, 2014 10:13 am ] |
so 30.000 yen is approx. $320 aus |
| Author: | Glenn [ Thu May 29, 2014 11:27 pm ] |
BULLITT wrote: so 30.000 yen is approx. $320 aus I have a 2L DOHC efi. Not sure what i am going to do with it now, but Webers are tempting ! |
| Author: | F3ARED [ Fri May 30, 2014 12:14 am ] |
flying wrote: Hi Nick Found this website in Japan that sells the manifolds I will post the link for the twin can manifold which is on page 4 but if you look on page 3 it would appear that the g161 twin webers manifolds -- no sure http://www.microsofttranslator.com/bv.a ... 26page%3D2 Cheers Flying Yeah I found those ones yesterday via Import Monster, unfortunately due to the design they are I cant use them as I have nowhere to mount the injector Glenn, jump on Import Monster, they act as the middle man between buying from Japan and sending to Aus. |
| Author: | Glenn [ Fri May 30, 2014 1:15 am ] |
F3ARED wrote: flying wrote: Hi Nick Found this website in Japan that sells the manifolds I will post the link for the twin can manifold which is on page 4 but if you look on page 3 it would appear that the g161 twin webers manifolds -- no sure http://www.microsofttranslator.com/bv.a ... 26page%3D2 Cheers Flying Yeah I found those ones yesterday via Import Monster, unfortunately due to the design they are I cant use them as I have nowhere to mount the injector Glenn, jump on Import Monster, they act as the middle man between buying from Japan and sending to Aus. I'm not ready to do anything right now. But good to know they are there. |
| Author: | flying [ Thu Jun 05, 2014 3:12 am ] |
Nick If you have to back to basics http://www.ebay.com.au/itm/2-x-Weber-DC ... 621wt_1128 Cheers Flying |
| Author: | Glenn [ Thu Jun 05, 2014 3:37 am ] |
flying wrote: Nick If you have to back to basics http://www.ebay.com.au/itm/2-x-Weber-DC ... 621wt_1128 Cheers Flying It might be cheaper to have them laser cut here in Oz? Especially if a few were made. You still need the other side anyway, to make a manifold so getting both made locally for a DOHC would be the go. Then find an alloy welder to weld in the tubes between them ? Not as 'nice' as cast ones but usable i would imagine. |
