| Trip meter https://bellett.net/forums/viewtopic.php?f=37&t=3298 |
Page 1 of 1 |
| Author: | Asroc66 [ Tue Jun 07, 2016 10:28 am ] |
| Post subject: | Trip meter |
Dear knowledgeable Belletters My speedo works well My odometer works well However my trip meter is a bit screwy Turns 1111 2222 3333 Etc I had a look inside but it's no easy job to remove the trip meter and a real risk of stuffing the speedo completely I am thinking 'live with it as it ain't so bad' Thoughts? J |
| Author: | Glenn [ Tue Jun 07, 2016 10:35 am ] |
| Post subject: | Re: Trip meter |
Asroc66 wrote: Dear knowledgeable Belletters My speedo works well My odometer works well However my trip meter is a bit screwy Turns 1111 2222 3333 Etc I had a look inside but it's no easy job to remove the trip meter and a real risk of stuffing the speedo completely I am thinking 'live with it as it ain't so bad' Thoughts? J I have pulled the ODO section apart, its not too hard. Not done the Trip meter though. There are some pictures in my Sports thread. http://www.bellett.net/forums/viewtopic.php?f=13&t=2084&hilit=bellett+sport&start=160 |
| Author: | Farmer [ Tue Jun 07, 2016 12:39 pm ] |
Yeah, its annoying that many trip merers don't work properly. Sounds like the wind back cable is stuck in as thats how they click back. Doris' will only wind back to 10 miles, but works normally. Aunty Mary's doesn't click the 10 column, so only counts 9 miles. There are people that rebuild them, but it costs a bit. I have a few spare sedan ones. Cheers, Matt. |
| Author: | redback [ Tue Jun 07, 2016 9:07 pm ] |
Hey Asroc, I had the same problem with my new Kilometres Per Hour one I installed a few months ago - the trip wasn't working and I put it down to my bad install. I had another go at it the other day because it was frustrating that it was not working - I fiddled with the reset/rewind knob on the dash and found a sweet spot, while I was driving (be careful) and it started working!! See how you go mate. Neil |
| Author: | Asroc66 [ Wed Jun 08, 2016 8:08 am ] |
Thanks Guys Got it sorted The dials were indeed stuck to the shaft Cheers J |
| Author: | Glenn [ Wed Jun 08, 2016 10:45 pm ] |
Asroc66 wrote: Thanks Guys Got it sorted The dials were indeed stuck to the shaft Cheers J so, did you dismantle ODO or just succeed in freeing them up mannualy. |
| Author: | Asroc66 [ Thu Jun 09, 2016 1:06 am ] |
Disassembled trip meter was really stuck, no way it was going to free up any other way Fairly straight forward, just keep every little piece in order J |
| Author: | Glenn [ Thu Jun 09, 2016 1:21 am ] |
Asroc66 wrote: Disassembled trip meter was really stuck, no way it was going to free up any other way Fairly straight forward, just keep every little piece in order J thanks My ODO was the same. essentially seized on the shaft with dust and crap. |
