View unanswered posts | View active topics It is currently Fri Jun 26, 2026 2:15 pm
Fuel Tank
Hi All
One of the problem areas is the fuel tank, upon removing I noticed what seemed to be small bits of rubber or some type of material between the tank and the body, is there supposed to be a gasket there?
Mark
Tue Apr 10, 2012 10:54 am
Mark,
Up to chassis number 4047852 there was a packing used. From there on there is no mention of any gasket. Most of the cars that I've worked on, have been a black sealant. In my sedan I used a sealant that is also to seal my windscreen rubbers. You may have something available at your local windscreen repair shop. That's where I got mine.
Tue Apr 10, 2012 11:58 am
Thanks Dave, thats helpful ...
We have a tacky rubber sealant that we use between cooling tower sections that will probably work fine when we put the tank back in the car ..
Mark
Tue Apr 10, 2012 12:18 pm
