oz_toffa
| Sat Aug 17, 2013 10:16 am |
pa_man
 Yep 4 ties to hold it down! 4 ties to hold it together!! Which were pretty much shredded by rust!!! AAhh Fun Times!!
| Sat Aug 17, 2013 11:01 am |
dave
B-pillar detachment!
Poor LUV...
| Sun Aug 18, 2013 12:14 am |
im sure if i bought that home my wife would have a few words to say! Is there any good bits left on it or did they fall off on the ride home? (might have to get a big tub of wd40 to soak the whole car in, so you can undo any bolts that are left!)
| Sun Aug 18, 2013 1:55 am |
oz_toffa
needed rear window from the cab. It was there and intact. so it went straight into the rear of the Captiva wrapped in packing. Done needed set of rims. Done Bosch GT40 coil in engine bay. Done Original Owners manual in glove box. Removed and packed away. Done Considered engine and gearbox removal. Engine seized. Head may be ok. Gearbox is column shift. coming out too. Not yet done. Still had original locking cap fuel and key in the ignition. key was seized but it was there!! Key now removed. Done Rego plates and Vin details still on the wreck. Easy rego walkin for my '72 Luv. Yeah that is so done!
and the price was right.
But it does need boxes of WD-40 and RP-7 to allow you to do anything at all.
| Sun Aug 18, 2013 7:28 am |
pa_man
Sorry Dave ALL PILLARS detachment Not Enough WD on the Planet  Gota Luv the fact the cap still has a sort of shine to it (considering the rest of the car)
File comment: Gota Luv the fact it still has a sort of shine to it (considering the rest of the car)
| Sun Aug 18, 2013 7:32 am |
pa_man
And Believe it Or Not the rear licence plate Is There....Hmm might need a new one Josh
| Sun Aug 18, 2013 7:38 am |
