bellett.net
https://bellett.net/forums/
What size wheel and offset on a Isuzu 117 Coupe
https://bellett.net/forums/viewtopic.php?f=4&t=3070
Author:  PeterB [ Sun Jun 21, 2015 8:23 am ]
Post subject:  What size wheel and offset on a Isuzu 117 Coupe
Hi Guys,
Thought I would create separate topics for each question incase people need to search the forum for it in the future.
I am trying to figure out what size wheels I can fit under the wheel arches of a 1974 Isuzu 117 Coupe PA95 XT (Yes I will keep stock + hub caps in warehouse for certain events). The car came with the original factory hub caps and I measured the current steel rims and they measured +35 offset.
Wheels: Watanabe Type R
Now the rears I wanted to fit the widest 15x8/8.5/9 with +0 Offset if I can as the rear guards are naturally pumped out already. The fronts well thats the headache I think, as with the +35 offset of the stock steelies the wheel literally sits on flush with the guard (attached image to see the difference between the front and rear) and I doubt I can fit 15x7 +20 offset unless the hub & double wishbone can be changed :S
Any info is greatly appreciated as I don't want to order the wrong wheels.
Regards
Pete
Author:  PeterB [ Sun Jun 21, 2015 8:24 am ]
Post subject:  Re: What size wheel and offset on a Isuzu 117 Coupe
Just realised there is a dedicated wheel section, admins please move if this should under there :)
Author:  Stickman [ Sun Jun 21, 2015 10:08 am ]
A 15x7 wheel with +20 offset should fit no worries as the more positive offset you have, the deeper inside the arch the wheel sits. I you go a +0 offset or a negative offset the wheel will have more dish and sit further out toward the arch.
Author:  Farmer [ Sun Jun 21, 2015 12:45 pm ]
Warren, who flagged you down, is a wheel & tyre bloke. I'm sure he would enjoy a test fit with some options. Should be plenty available as they are the same pattern as Datsuns.
I personally wouldnt mess with the wishbones, parts are rare. Please dont think of flaring the guards, those lines are so sweet!
Author:  PeterB [ Sun Jun 21, 2015 1:03 pm ]
Sorry I meant I wanted to roll the guards , the inner lip for more clearance
Author:  Asroc66 [ Wed Jun 24, 2015 2:19 am ]
Check out these Bad Boys
Wantanabe's 14 x 6
http://www.ebay.com.au/itm/WATANABE-RIM ... 1a01f05668
Author:  PeterB [ Wed Jun 24, 2015 9:47 am ]
$2400 for a second hand set?
They are cheaper new :)
Author:  Asroc66 [ Wed Jun 24, 2015 10:52 am ]
Surely not!!!!!!
I read it as $680 per set of 4....
Did u email the dude?
I know you pay for the name but if you are right that's just crazy.
They are the period mags to have..... Would love a set that's for sure
Author:  Farmer [ Wed Jun 24, 2015 11:39 am ]
Surely its $680 for the set, though there is a 1 in the quantity box. Not a pleasant seller by the blurb. :?
I'm not a fan of black wheels, but to each his own.
There are heaps of choices that would fit under the stock guards.
Author:  PeterB [ Mon Jul 06, 2015 10:53 am ]
Couldn't resist new badges are my weak spot.
Author:  Stickman [ Tue Jul 07, 2015 8:17 am ]
VERY nice :)
Page 1 of 1 All times are UTC
http://www.phpbb.com/
