| Front Indicator Lense 67 GT Bellett https://bellett.net/forums/viewtopic.php?f=6&t=1451 |
Page 1 of 1 |
| Author: | flying [ Sun Apr 24, 2011 11:25 pm ] |
| Post subject: | Front Indicator Lense 67 GT Bellett |
I am chasing 1 white glass bee hive lense for the GT Any clues of where to source Regards |
| Author: | KJB [ Thu Apr 28, 2011 10:12 pm ] |
| Post subject: | Re: Front Indicator Lense 67 GT Bellett |
Looking for a couple myself - - this on EBay ( Item - 380193060716 ) caught my eye , might be a good option until correct lens turns up. Probably need a little modification but should not be expensive and is readily available. KB |
| Author: | gt orphanage [ Thu Apr 28, 2011 10:29 pm ] |
Another option is the later style pr90 set up. You can't get them but i got a set of toyota one that are the same from japan. If someone has a parts book i need a part number i will see if it can be got out of japan? btw if you need the hole assy they are left and right. |
| Author: | BULLITT [ Fri Apr 29, 2011 12:04 am ] |
hi greg PART NUMBERS ARE THE BEEHIVE LENS 8262-1253 THEN HAS (AP20-00002) UNDER DESCRIPTION EXPLODED VIEW 8262-0197 FLASHER LAMP ASSY R.H. (AF101-8) 8262-0198 L.H. (AF101-7) CHEERS DAVO |
| Author: | PR91 [ Fri Apr 29, 2011 12:13 am ] |
i'll double check before anyone commits to buying them, but i think good ole morris minor indicator lense are exactly the same type.... but only if u can handle having the word "lucas" on a bellett. they are readily available. let me verify this first tho, and i'll re-post. |
| Author: | gt orphanage [ Fri Apr 29, 2011 2:01 am ] |
i will sit back until i know they want them before we chase them then thanks Brett. |
| Author: | KJB [ Fri Apr 29, 2011 3:50 am ] |
I thought that I needed 2 but I have just found them. Mini minor lenses look like they may be a good option for anyone wanting lenses. KB |
| Author: | flying [ Fri Apr 29, 2011 11:10 am ] |
I had a spare with Lucas on it -- Almost the same slightly smaller diameter but you could make it fit if nothing else was available |
