| Oil Pressure SENDER https://bellett.net/forums/viewtopic.php?f=6&t=3227 |
Page 1 of 1 |
| Author: | 1968GT [ Wed Feb 10, 2016 10:03 pm ] |
| Post subject: | Oil Pressure SENDER |
Looking for an alternative or Gemini part number for an oil gauge sender that suits the Bellett. I believe a Gemini will fit and work, however I would like the correct part number if anyone has it please? My pressure switch at the lower RHS rear, side of the engine has developed a minor leak and I wish to replace it ASAP. If anyone can help please before I rush out and buy an incorrect part! I know it is on here "somewhere", I have looked and can not locate the post. Dave M. |
| Author: | Glenn [ Wed Feb 10, 2016 11:18 pm ] |
| Post subject: | Re: Oil Pressure switch |
1968GT wrote: Looking a alternative or Gemini part number for an oil switch that suits the Bellett. I believe a Gemini will fit and work, however I would like the correct part number if anyone has it please? My pressure switch at the lower RHS rear, side of the engine has developed a minor leak and I wish to replace it ASAP. If anyone can help please before I rush out and buy an incorrect part! I know it is on here "somewhere", I have looked and can not locate the post. Dave M. Dave see http://www.bellett.net/forums/viewtopic.php?f=36&t=3103&p=31691&hilit=oil+pressure#p31691 |
| Author: | 1968GT [ Sat Feb 20, 2016 3:46 am ] |
| Post subject: | Re: Oil Pressure Gauge SENDER |
Well I have found out what I am after, I used the incorrect terminology, I am looking for the OIL PRESSURE GAUGE "SENDER"! (Mine in the GT has sprung an oil leak) I have found a Yazaki sender for the Yazaki gauges, (after market) I have ordered the part and will advise after fitted how it works. It is a part used over the same model years as Isuzu in the Bellett, only in the Toyota Hi Lux for Yazaki gauges, fingers crossed it works!! |
| Author: | 1968GT [ Wed Mar 02, 2016 11:21 pm ] |
| Post subject: | Re: Oil Pressure SENDER |
I now have the part and it looks good. As I am about to be away for a while, the installation will have wait until I return. I will let you know. |
