| 1969 Indicator Stalk https://bellett.net/forums/viewtopic.php?f=6&t=404 |
Page 1 of 1 |
| Author: | 2ldohc [ Sat May 09, 2009 12:24 am ] |
| Post subject: | 1969 Indicator Stalk |
Hi All, I'm hoping that someone out there in Bellett world has a spare indicator stalk with the high beam on it from the late model. Mines gone all floppy so I can't get it to stay turned on going left... Even if someone has a broken one I might be able to make one working one from them! Thanks, Ross. |
| Author: | 65bellett [ Sat May 09, 2009 8:15 am ] |
| Post subject: | Re: 1969 Indicator Stalk |
I used a Mini Clubman one in my Car it looks like it should be there and will be easy to get a replacement if it fails. It might be worth getting down to U-pullit and finding something common that looks and fits alright. And then you can tell us all about it and save us some leg work when ours go floppy. pull it, floppy |
| Author: | BrisBellett [ Sat May 09, 2009 8:35 am ] |
Hi, did the clubman indicator cancel out after your turned? If so then the new Hillman Hunter ones I have will work just fine and they are bent upwards which makes more room for the legs getting in/out and whilst driving. Clyde. |
| Author: | Farmer [ Sat May 23, 2009 12:37 pm ] |
Ross, I do have 1 somewhere if you still need it. Lets know if you want it sent, or if you can wait till the nats. Regards Matt. |
| Author: | 2ldohc [ Sat May 23, 2009 2:03 pm ] |
Hey Matt, I've pulled mine apart to have a look and the casting is worn right away and the little ball bearing that is held by a spring has fallen out. If you have one that would be great. The indicators and stalk are good it's just the main casting that is stuffed! I can wait til the nats if you can just pack it in a bag for me Thanks, R. |
| Author: | Farmer [ Tue May 26, 2009 9:57 am ] |
It's yours, mate. I'll bag it & bring it . Cheers, Matt. |
| Author: | 2ldohc [ Tue May 26, 2009 1:03 pm ] |
Thanks! My stalk won't be floppy ever again... R. |
| Author: | Farmer [ Wed Aug 19, 2009 11:30 am ] |
Hey Ross, I found the stalk the other day while scratching through parts. It appears to be nice & firm and functioning as desired. There was a minor panic when I first found a stalk whuch is only a dimmer switch & not a blinker. (Oh no, is this what I was thinking of ?) Don't know what it fits. It's in the boot ready to go. Cheers, Matt. |
| Author: | 2ldohc [ Wed Aug 19, 2009 1:11 pm ] |
Hey Farmer, Thanks heaps! It's driving me nuts how it is. Look forward to seeing you at the nationals Cheers, Ross. |
