View unanswered posts | View active topics It is currently Thu Jun 11, 2026 11:36 pm
Reply to topic  [ 32 posts ]  Go to page Previous  1, 2
Bellett 4:11 diff gears
Car(s): 1968 Bellett GT
haha no i dont think you would have all reverse gears as im pretty sure with a 4x4 the tailshaft going into the diff spins the opposite way to the rear tailshaft.
Sat Sep 22, 2012 9:17 pm
Or turn the diff. centre over.
Sat Sep 22, 2012 11:29 pm
how much do you want for your front diff posted to qld? ill pull it apart and see if it fits...i doubt it but...if not ill stick to the 4:11 florian center
Tue Sep 25, 2012 8:55 am
Car(s): 1980KBD40 ISUZU
If the above ? is for me i can pull a center apart and take measurements.
Tue Sep 25, 2012 9:12 am
Right click to open larger pics in new tab.
Tue Sep 25, 2012 10:57 am
Pinion bearings - smaller bearing 30305c larger bearing 02420
Crown bearings LM4851c-cup LM48548a-cone
22t spline count 41 teeth on crown 9 on pinion = 4.56
Tue Sep 25, 2012 11:03 am
ozluvtrucker ..love your postings its good when you can ask the auricles when you have tricky questions ..again this is why the forum works cheers davo great shots of the diff ...
Tue Sep 25, 2012 1:04 pm
wow awesome pics mate damn looks so similar ill have to go up in the shed and take a look at the pinion gear tomorrrow and let you know! but looking at it right now it looks damn much the same!
Wed Sep 26, 2012 8:22 am
just checked and the pinion gear is slightly differant...it has like a differant bearing holder
Wed Sep 26, 2012 9:14 am
Bugger :|
Wed Sep 26, 2012 10:01 am
hang on a minute! my bellett crown wheel look the same the bellett has 41 teeth the only thing is the pinion gear..but when i looked at mine the bearing runner is pressed on so its not part of the pinion shaft itself..can you measure exactly how long the pinion gear is and also the thickness of the shaft were the bearing sits. the spline is differant but i can use the spline that you have in your picture..can you measure the diamtere of the crown wheel also...need precise measurement...but it might be a case of a tiny bit of machining and it will work!!
Thu Sep 27, 2012 5:32 am
just comparing the pics it looks like a goer!! just need to use the front spline part that the tailshaft bolts too!
Thu Sep 27, 2012 5:34 am
