The one bellett part I really really want is a............
Re: The one bellett part I really really want is a..........
Post by Stickman »
PR91 wrote:Not saying the rumour is correct.... Never confirmed myself, so hence, rumour.
Dean, number is 4110. Normal one is 4111.
Early version diff's are 379 for a 4.1 and 349 for 3.7. I want a 4110 tho.
I'll check my spare ones I have at my brothers place for you as soonn as I have a chance, may be a couple of weeks before I can get there though.
Post by PR91 »
Cheers.
No hurry.... Has a date with the welder before its used next year. ;)
Post by PR91 »
Numbers are stamped into the vertical rib under the fill plug.
pa_man
Post by pa_man »
We have also got a couple of auto wrecks so will have a look Brett (after Nats Prob)
PR91 wrote:Numbers are stamped into the vertical rib under the fill plug.
no rib or numbers here Brett.
Gunna
Post by Gunna »
pa_man wrote:We have also got a couple of auto wrecks so will have a look Brett (after Nats Prob)
8-) You got them okay?
pa_man
Post by pa_man »
Yep not a problem, Many thanks.
Got another auto as well so checking both at some point. Josh
Dean. Yesterday i dropped diff off to the guy for a check over. Will take 2 weeks. So i have two weeks to get this one out. I discovered that the x member can be removed from the diff without removing the yoke. You have to unbolt the diff of course then wiggle the x member at an angle and it comes off. I hope i can do that under the car to avoid removing several brake lines.
Post by BULLITT »
Farmer heres health ??
Post by BULLITT »
Coming a close second behind the elf is a bellett
Post by Stickman »
Glenn wrote:https://www.abouttimespares.com.au/showpartslist.asp?cat=23
Some parts available
I've bought a bit of gear off these guys over the years.
This is where I got Donkeys drivers door weather shield from..... they had 2 listed at the time (1 clear, 1 green tint) so I ordered both but they could only find the clear one in the warehouse (been on Donkey ever since)
I got my reco'd diff back today. (Thanks Dean) It has the numbers on the casting as you suggested Brett. Slightly different sequence. You can see that the late model diff is totally different in the casting. The reco guy said he in his Bellett search, there are four different ratios listed. Obviously not in Oz though.
For the info of others, he got maybe the last of the carrier bearings available. The bearing is wider than any other that might fit. That would required spacers to be made etc. Driveshaft seals are not available.
Its weird, the differences. Change for change sake or are they improvements? The late diff has the drain on the rear. Obscured by the leaf spring so thats a backward step!
Post by mrflibbles »
the one bellett part i really really want is a Florian Wagon/van!
