G150 Rebuild Kits?
- redback
- Contact:
Re: G150 Rebuild Kits?
Yes I am absolutely going to remove welch plugs for an acid bath (it has been sitting in the back of my shed for 10 years I think - I remember doing the same for the motor in Stinky now.
It is not a rant when it is advice CQ - all good. I am very open to advice - that is why I post these things so Bellett.net can give me heads up!! I thank you all!
Thanks Dave for the info on the Cam Bearings - will let you know how I go.
- Glenn
- Contact:
has anybody solved this problem of cam bearings ? I had same issue way back in 90's on the GT engine rebuild.gt orphanage wrote:just make sure you can get cam bearings before you go acid bathing itthey are a little hard to find
PR95
Somewhere in the old memory bank I recall that 1200 Suzuki Motor cycle bearings were being modified to fit.
I think you will find that Suzuki mod was twin cam.
- Glenn
- Contact:
does anybody have the dimensions of the bearings (Bellett that is)
- redback
- Contact:
Hello Glenn,
I found this info on camshaft bearings this morning:
Camshaft Bearing Set 3C6127
Oversize STD
Brand ACL
Manufacturer ACL
Camshaft Bearing (c) 6127
- 1,2,3
OE Part Number 1 5-11611-002
Manufacturer ACL
Min Std Shaft Size 1.7707in / 44.975mm
Max Std Shaft Size 1.7707in / 44.975mm
Min Std Tunnel Size 1.8902in / 48.01mm
Max Std Tunnel Size 1.8909in / 48.03mm
Max Wall At Crown 0.0591in / 1.5mm
Max Overall Length 1.0000in / 25.4mm
Semi-finished N
Min Vertical Oil Clearance 0.0014in / 0.035mm
Max Vertical Oil Clearance 0.0037in / 0.095mm
Material F23
MAIN BEARINGS:
Main Bearing Set 5M2817
Oversize STD, .25, .50, .75, 1.00, 1.25, 1.50
Brand ACL Duraglide
Manufacturer ACL
Main Bearing (c) 2817
- 1,3,5
Half Type Identical Halves
OE Part Number 1 9-11510-609
OE Part Number 2 9-11510-141
Manufacturer ACL
Min Std Shaft Size 2.2016in / 55.92mm
Max Std Shaft Size 2.2022in / 55.935mm
Min Std Tunnel Size 2.3220in / 58.98mm
Max Std Tunnel Size 2.3228in / 59mm
Max Wall At Crown 0.0596in / 1.513mm
Max Overall Length 1.2650in / 32.13mm
Min Vertical Oil Clearance 0.0007in / 0.019mm
Max Vertical Oil Clearance 0.0031in / 0.08mm
Material F780
Main Bearing (c) 2818
- 2,4
Manufacturer ACL
Max Overall Length 0.8299in / 21.08mm
Material F780
Hope that helps mate.
Oversize STD
Brand ACL
Manufacturer ACL
- 1,2,3
Manufacturer ACL
Semi-finished N
Material F23
MAIN BEARINGS:
Brand ACL Duraglide
Manufacturer ACL
- 1,3,5
Manufacturer ACL
Material F780
- 2,4
Manufacturer ACL
Material F780
I have a new set here a forum member helped me get
it's up to that forum member to say if he can get more as I think the supply is low if not gone.
- Glenn
- Contact:
Thanks Neil
I don't need any now, but the info could help soembody out maybe. I wonder if the SOHC and DOHC lay shaft uses the same bearings.... i would imagine so.
last time I checked acl no longer had stock and were not making any
Maybe a group buy I would get a couple more sets.
- Glenn
- Contact:
thatmight be the way to go, a group buy or maybe a Club purchase as these will always be a problem otherwisegt orphanage wrote:last time I checked acl no longer had stock and were not making anyMaybe a group buy I would get a couple more sets.
gt 161
- Car(s): Gt Bellett, Rover 90, Rover 75 ,327 hk Monaro, 307 ht Ute, Mazda 6 wagon.
I have already checked with acl about getting them remade and they will do them but need to order a min of 300 sets very expensive I'll have a look through my spares as I should have a few spare sets that I won't need. Peter.
- Glenn
- Contact:
Hi Peter,gt 161 wrote:I have already checked with acl about getting them remade and they will do them but need to order a min of 300 sets very expensive I'll have a look through my spares as I should have a few spare sets that I won't need. Peter.
do you know if they also fit SOHC and DOHC engines.
The ones I have are nason 3c6127n made in Taiwan box says for g130/150/161/180/200 ? Maybe they might be of help
gt 161
Hi Glen they will fit 1800 block as well
- Glenn
- Contact:
thanks Peter.gt 161 wrote:Hi Glen they will fit 1800 block as well
(long time no see, mate)
- Glenn
- Contact:
might be worth asking at Bursons etc........ thanksgt orphanage wrote:The ones I have are nason 3c6127n made in Taiwan box says for g130/150/161/180/200 ? Maybe they might be of help
