Page 2 of 2
Re: Water pump questions - my Luv has leaked all of its cool
Posted: Sun Apr 12, 2015 6:59 am
by Anthiron
Hi Davo
I would be very keen to order a pump if you could put me in contact with this supplier.
Nick
Posted: Sun Apr 12, 2015 10:43 pm
by Farmer
Hi again, the little hole also frevents water flowing into the sump and causing possible huge damage, so dont be tempted to silastic it!
I am away visiting my brother, but have a pump that holds water on a Luv (Josh's). I will get it off and send it, at least it might get you mobile while we all search. I will then have a motor to test other used pumps on.
In my experience, Aus delivered sedans, GTs, Florians and G161 O.H.V. Luvs all have the same pump, with 3 bearing motors 64 to 66 not using the backing spacer plate. The seal detail is different on early pumps I believe too.
Do run Ethylene glycol coolant, (green) even in warm climes as the alloy corrodes readily.
Will be a week or so,
Posted: Sun Apr 12, 2015 11:20 pm
by Anthiron
Hi Matt
You have a PM.
You're a gentleman and a scholar.
Nick
