Steering, ball joint and tie rod end boots
Posted: Fri Oct 24, 2008 6:56 am
by BrisBellett
Hi, Most likely someone has published this info before but here it is again - just in case:
Steering rack boot - Repco Universal fit - URPB
Tie rod end boots and steering rack end boot - TE2
Ball joint boots - TE8
Cheap spring ties are just that - cheap - they break easily so some had standard cable ties to secure.
cheers, clyde
Re: Steering, ball joint and tie rod end boots
Posted: Thu Feb 12, 2009 1:43 pm
by GTtoo
Ta Bris,
Exactly what I'll be looking for next. Any idea on were to go for rack ends and tie rods, also worn ball joints. Also need bushes, and rubbers for the rack mounts which are non existant, thus moving the whole rack by about 5mm to add extra slop.
Cheers, from " tired and shakey front end" Bruno.
Posted: Wed Mar 03, 2010 10:30 am
by RobSA
Have a guess what these are ?
Yes, they are brand new.
Rebonded engine mounts can be got to
Posted: Wed Mar 03, 2010 9:24 pm
by 1968GT
Rob,
Where do get the engine mounts re bonded please?
Is it worth having a quantity done for a number of us and would it be any cheaper??
I would be interested in at least 2 pair of engine mounts as spares.
Posted: Wed Mar 03, 2010 9:56 pm
by gt orphanage
I would support this order looking at 6 mounts
Greg
Posted: Wed Mar 03, 2010 10:58 pm
by RobSA
I'm not sure how quickly then can be turned around (ie delivered rebonded, sent out or picked up).
I've asked to have two sets of engine mounts and two sets of rack rubbers in the next month.
AJ posted this link awhile back ...
http://www.bellett.net/forums/viewtopic ... shed#p3415
I rang him and went down there.
I haven't had a price yet. Does it really matter? Much better than cutting up some other mounts.
If you don't have a mount with the steel, Tony can make them up, but much better to take in your old mount.
I will be getting another two done once the new ones have replaced the ones on the cars (does that make sense).
Posted: Thu May 03, 2012 5:57 am
by Glenn
this is an old thread re steering rack rubbers...... where do they come from ?
Posted: Fri May 11, 2012 11:40 am
by RobSA
Glenn all the details are in this post, the guy who makes the engine mounts also makes the steering rack rubbers
viewtopic.php?f=36&t=574&p=3415&hilit=refurbished#p3415
Posted: Sat Nov 16, 2013 3:10 pm
by 65bellett
Cheers Brisbellett I just jumped on to ask about steering rack boots and you had all ready put up the answer. Who says owning a Bellett is a lot of hard work to find parts and keep on the road
Posted: Fri Nov 28, 2014 6:22 am
by Classic_Bellett
A&A ENGINEERING
They specialise in standard and high performance Harmonic Balancers.
But they also specialise in Re-bonding rubber mounts, and all types of specialise rubber components.
The rubber is top quality! and they deal with anyone Australia wide.
Speak to Tony.
