GT Satndard Air Filter elements.
Posted: Wed Jan 25, 2012 5:49 am
by 1968GT
Guys,
I am hunting for the above, my GT has Fram filters in it now CA2648 code number. The problem being as of now I can not find an equivilent, Fram nowadays do not list the above number in their catalogue, they only list a CA2646.
If you know of a air filter that fits, would you please let me know the brand and part number, if possible where to get them from??
Re: GT Satndard Air Filter elements.
Posted: Wed Jan 25, 2012 7:16 am
by gt orphanage
Time for me to fess up
i get mine from the local mower shop that has a display for kohler engines there are a few i just matched them to the same size.
Posted: Wed Jan 25, 2012 7:20 am
by JT191
Characteristics
Height : 56 mm
Ø exterior : 213 mm
Ø Interior : 159 mm
Barcode
5022650200802
If that is accurate, these are close:
http://www.knfilters.com/search/product ... rod=E-9173
Height: 2.313 in (59 mm)
Inside Diameter: 6.625 in (168 mm)
Outside Diameter: 8.344 in (212 mm)
http://www.knfilters.com/search/product ... rod=E-3492
Height: 2.375 in (60 mm)
Outside Diameter: 8.5 in (216 mm)
Probably others in their database that are close, not sure which dimensions are the limiters:
http://www.knfilters.com/search/univ2.aspx?ID=S0001
Reusable cotton, outlasts the car.
This one is listed for Rover Allegro (the Fram number):
http://www.knfilters.com/search/product ... rod=E-2600
Height: 2.188 in (56 mm)
Inside Diameter: 6.25 in (159 mm)
Outside Diameter: 8.188 in (208 mm)
Posted: Wed Jan 25, 2012 9:42 am
by rod
dave i use ryco fiat ryco a 134 contact super cheap or bursons this was in parts interchangeble
Posted: Wed Jan 25, 2012 2:09 pm
by PR91
as posted by rod, and listed in the "parts interchangability" section:
ryco premium # A134.
baldwin filters # P505295.
let us know how u get on dave.
Posted: Thu Jan 26, 2012 6:21 am
by GTtoo
Hi guys,
Yep, the same. I've recently changed mine and those two PR91 has quoted were available from autopro as well. Thing is that all are not exactly the same. As JT points out, some are taller. However, there is a fair bit of room to accomodate height under bonnett. The real problem though is, some have a thinner rim with a slightly larger inside diametre. These only just fit onto the mounting rim and need to be very carefully positioned to make a seal.
Cheers, B.
Posted: Sat Jan 28, 2012 5:47 am
by 1968GT
Thanks Guys, always very helpful.
Sorry Brett, you know what its like as you get older, I keep forgetting the Interchangeable parts listing, DUH!!
I only checked mine before Motofest and realised they need replacing.
GREAT STUFF, thank you again.
Re: GT Standard Air Filter elements.
Posted: Wed Feb 01, 2012 5:52 am
by 1968GT
Thank you Guys, really happy
My problem has been resolved, the Ryco number you supplied, has an equivalent in WESTFIL filters
WA134, as you can see it relates back to the Ryco A134.
Your assistance and advice helped!
I did not realise the air filters were so in need of replacement until I was tidying up for Motofest 2012
Brett, add this to your list if it is not there as yet, I looked but could not find the listing on the Web.
Rod, Brett and JT191, thank you again
