GT Parts needed
Posted: Wed May 30, 2012 6:26 am
by claws
Am starting my GT resto so just putting it out there if anyone is willing to part with any of the following, let me know......after you get back up off the floor
Tacho
1600 head gasket
extractors
exhaust gasket
Craig
Re: GT Parts needed
Posted: Wed May 30, 2012 6:52 am
by Glenn
might be a tough ask for some of those parts.
Jason has a few Bellett parts in another thread in Japanese auctions. Keep an eye on that, some of the bits might turn up.
I think i have a s/h exhaust gasket somewhere.
The BCCV used to have Gasket kits but i think none left although possibly that might change if they find/get made some more..
Re: GT Parts needed
Posted: Wed May 30, 2012 8:07 am
by gt orphanage
head gasket repco part no is cj151 acl brand it is a valve regrind set with tappet cover gasket ect for a luv. manifold gasket is not going to work.
I have manifold gaskets made they are $40 each i am out at he moment but another ten are being made.
extractors are on the go too i have a luv 1 made for the race car and the gt gasket and manifold are going down next to lazer cut the plates soon. i only got a call yesterday to say the luv plate is done.
Re: GT Parts needed
Posted: Wed May 30, 2012 9:21 am
by Glenn
my enquires down here for that set have shown no stock. Only the valve seals are still available.
Re: GT Parts needed
Posted: Wed May 30, 2012 9:46 am
by gt orphanage
We got a few sets a couple of weeks back, let me know if you have no luck we have a contact at acl
Re: GT Parts needed
Posted: Wed May 30, 2012 9:53 am
by Glenn
Don't need one but was there getting other stuff so thought i would ask
BCCV though should get a few
Re: GT Parts needed
Posted: Wed May 30, 2012 9:55 am
by BULLITT
mate how did you lose the tacho or did it die ? have seen them come up on the o/s look what we have market place cheers davo
Re: GT Parts needed
Posted: Wed May 30, 2012 10:00 am
by gt orphanage
If it's only dead otto instruments put a new guts in them past experience is they are wired wrong you have to swap the two wires around the tacho overides the points a she no go
Re: GT Parts needed
Posted: Wed May 30, 2012 10:06 am
by mrflibbles
is the 1500 head gasket the same as the 1600?
Re: GT Parts needed
Posted: Wed May 30, 2012 10:09 am
by gt orphanage
they would be in the bore size but i use them on 1500,s
Re: GT Parts needed
Posted: Wed May 30, 2012 11:06 am
by claws
Car didnt come with tacho or extractors, Was sitting on a farm for about 7-8 years. Had back windsceen smashed by vandals. tacho was either stolen or was placed by owner in one of his 6 or 7 sheds, unlikely to ever be found again in my lifetime. Likely there will be other parts missing as I progress but these are the most obvious peices at the moment.
Re: GT Parts needed
Posted: Wed May 30, 2012 12:22 pm
by PR95
I have a tacho from a 117, the same as GT. don't know what condition it is in, if you are interested pm me
Geoff
Re: GT Parts needed
Posted: Fri Jun 01, 2012 11:08 am
by PR91
had to make a set of extractors a few years ago for mine.
originals are over 40 years old now, and 90% are stuffed. my originals were waffer thin, and was a never ending job to patch them up, so i made a brand new set instead.
should be ok for another 40 years.
Re: GT Parts needed
Posted: Fri Jun 01, 2012 11:13 am
by Glenn
did ypou make yourself Brett or get them made ?
Re: GT Parts needed
Posted: Fri Jun 01, 2012 11:26 am
by PR91
me Glenn. but did it in a mates exhaust shop when he still had it.
used the original mounting plate, but all new pipes and now a flat, bolt on flange to the exhaust, not a slip joint.
not that hard to do, and i'd still do my own even tho he doesn't have the shop anymore, but with bends and straight pipe sections u can buy separately, because a good exhaust shop with A: someone who cares, and B: someone who actually knows how to do custom work as opposed to "bolt off, bolt on" is getting bloody hard.
there are some around that do very nice work, but they know how to charge too....
mind u, my standards of what i'll except as a good job is probably higher than some, so i can be critical sometimes.
Re: GT Parts needed
Posted: Fri Jun 01, 2012 11:35 am
by Glenn
yes, i have done one myself using U bends when i had the 1600 DOHC toyota motor in the white GT. Tedious but easy enough to do.
Not much choice though, toyota in a bellett, no off the shelf stuff LOL
Re: GT Parts needed
Posted: Fri Jun 01, 2012 11:02 pm
by PR91
bellett in a bellett (ie: original) and there no off the shelf stuff either...
