CHOKE CABLE
Posted: Sun Aug 17, 2014 9:11 pm
by BULLITT
hi I am chasing a choke cable for the 90 anyone got spares ??... I have a good black ''c'' which you pull ( this don't sound good but you get the idea ...do you ) just cable is r/s ..have cash waiting cheers davo
Re: CHOKE CABLE
Posted: Sun Aug 17, 2014 10:50 pm
by Glenn
BULLITT wrote:hi I am chasing a choke cable for the 90 anyone got spares ??... I have a good black ''c'' which you pull ( this don't sound good but you get the idea ...do you ) just cable is r/s ..have cash waiting cheers davo
there used to be, maybe still, universal Choke cables available from Auto stores, if all else fails, Dave
Re: CHOKE CABLE
Posted: Fri Aug 22, 2014 11:25 am
by yellowperil
Glenn is correct, I had to replace the choke cable in the yellow peril some time ago and found one at either Repco or Bursons ( I can't remember which as I find lots of universal parts at both).
It is branded as Bonnet release/ choke cable and you cut it to the desired length. the only problem was that it comes with the cable attached to a standard black knob, not the one with the "C" in the middle. Cheap as chips, around $20 from memory., threaded in nicely and was long enough to give a nice wide loop for easy operation. Piccies attached
YP
Re: CHOKE CABLE
Posted: Sat Aug 23, 2014 12:47 am
by Glenn
yellowperil wrote:Glenn is correct, I had to replace the choke cable in the yellow peril some time ago and found one at either Repco or Bursons ( I can't remember which as I find lots of universal parts at both).
YP
for a more 'original' under bonnet look, buy some black heat shrink tubing from Jaycar or Altronics and shrink it over the exposed outer, once the length is worked out.
Re: CHOKE CABLE
Posted: Sat Aug 23, 2014 1:17 am
by BULLITT
thanks guys got a brand new one from Caloundra it has the original 'c 'on it great it looks as the old one ..im stoked $20 cheers davo
Re: CHOKE CABLE
Posted: Sat Aug 23, 2014 1:26 am
by Glenn
BULLITT wrote:thanks guys got a brand new one from Caloundra it has the original 'c 'on it great it looks as the old one ..im stoked $20 cheers davo
good work, Dave.... keep chipping away.....
Re: CHOKE CABLE
Posted: Sat Aug 23, 2014 12:17 pm
by Farmer
Good result mate,
cheers, Matt.
