Rocker cover gasket
Posted: Sun Jan 29, 2017 11:14 am
Hi all and GTtoo -
I am chasing a gasket for my GT to fix a bad oil leak - old one has distorted and moved and is a mess.
Auto Surplus in Mitcham have 2 made from cork, but seem to bee very thick at about 5-6mm and also a tad expensive ($45 !!!!).
Glenn gave me a link to GTtoo from a couple of years ago and his work in cutting some new ones from cork. The question is - are any still available?????
The alternative is to buy a sheet of neoprene rubberised cork and cut a couple for me and for whoever else may need them. This sheet is more like the gasket I have - more rubber than cork and about 3mm thick. It came from a complete engine gasket set many years ago. Size of the sheet from Auto Surplus is about 1200mm x 650mm and priced at $80. This would work out to about $10 per gasket, which is a much better alternative if there is a need for more gaskets.
Cheers, Barrie.
Cheers, Barrie.
