Interior Door Trim and Rear Quarter Panel Clips
Posted: Thu May 06, 2021 12:52 pm
by peterd
Does anybody out there have any of these clips they wish to sell or point me in the direction to obtain some?
The secure the stainless strip on the inner door cards and rear quarter. I believe they are unique to the GT but could be wrong.
Re: Interior Door Trim and Rear Quarter Panel Clips
Posted: Fri May 07, 2021 1:29 am
by KJB
Try..... Wirth...... they market a really wide range of good quality clips etc.. May even have a plastic equivalent.
Also - Motor Trade Suppliers.....Vic.
Posted: Fri May 07, 2021 4:57 am
by Glenn
peterd wrote:Does anybody out there have any of these clips they wish to sell or point me in the direction to obtain some?
Similar are fitted to my Sport holding the door pockets. I had some tin plate that i just cut up and bent to suit. Worked fine. Maybe even a tin can. Probably will last as long as the originals.
Posted: Fri May 07, 2021 5:00 am
by Glenn
KJB wrote:Try..... Wirth...... they market a really wide range of good quality clips etc.. May even have a plastic equivalent.
http://www.motortradesuppliers.com.au/mts/default.aspx
Posted: Fri May 07, 2021 10:38 am
by CQGT
Hi Peter.
Try a craft shop. A shop that has paper, ribbon, matchsticks, paddle pop sticks and all sorts of fasteners.
We have Sollys. Dollars and Sense. Less than $5.00 stores. In Qld.
They may have a round head on them but all it needs is have it fit the slot.
Posted: Mon May 10, 2021 3:13 am
by flying
Hi
Try Paper Binders from a stationary store
Posted: Mon May 10, 2021 1:29 pm
by CQGT
Flying.
Yes. I reckon would do the trick. Bend the tops to fit the slot. The washers would assist with the pressure
to hold onto the backing panel.
Posted: Tue May 11, 2021 5:08 am
by peterd
Thanks Guys for all your help with this. Paper binders are the way to go and I have found the perfect fit with a little trimming.
Thanks again
Regards
