Bolt on four pot brakes?
Posted: Fri Jun 11, 2010 6:44 pm
by JT191
Re: Bolt on four pot brakes?
Posted: Sat Jun 12, 2010 7:37 am
by bellett65
I will be the devils advocate here. They could not be used in Aus. even if you could get kits for them. Tghe rules here are quite clear. You have to use at least 3 of the original mounting holes. Apart from the welded in fill? only 2 mounting holes used. Where 4 were used on the original. Whether it was drum backing plate or caliper mounting bracket it does not matter. Brake and safety go hand in hand. :ugeek:
Posted: Sat Jun 12, 2010 1:46 pm
by JT191
bellett65 wrote:I will be the devils advocate here. They could not be used in Aus. even if you could get kits for them. The rules here are quite clear. You have to use at least 3 of the original mounting holes. Apart from the welded in fill? only 2 mounting holes used. Where 4 were used on the original. Whether it was drum backing plate or caliper mounting bracket it does not matter. Brake and safety go hand in hand. :ugeek:
For GT? It should be just two bolts holding the original caliper, right? If it were a conversion for a car which came with drums, that sounds like a problem. But would I have to add two more bolts if it only came with two just so that I could upgrade calipers?
Posted: Mon Jun 14, 2010 12:26 am
by bellett65
As per piccy
Posted: Mon Jun 14, 2010 2:13 am
by JT191
Posted: Mon Jun 14, 2010 7:27 am
by RobSA
Posted: Mon Jun 14, 2010 3:20 pm
by JT191
This is what I am thinking:
Posted: Tue Jun 15, 2010 12:55 pm
by RobSA
Sounds pretty good.
Posted: Tue Jun 15, 2010 2:27 pm
by JT191
RobSA wrote:Sounds pretty good.
That's the smallest Wilwood vented disk is 10 1/4. That extra 1/2 inch diameter is probably going to cause a lot of clearance problems. With the 9.9 inch Nissan rotor, 13 inch steel wheels might fit. And they are $75 USD, almost twice as much as the Nissans. The Nissan rotor bolt pattern is more similar to the Bellett, so the hat or adapter will be more compact and simpler. Using this extremely large caliper on a small rotor causes clearance issues between the inside edge of the caliper and the hub.
Posted: Tue Jun 15, 2010 8:11 pm
by JT191
So, I have bad news.
Posted: Thu Jun 17, 2010 12:02 pm
by PR91
have a look here:
http://www.bellett.net/forums/viewtopic.php?f=13&t=709
Posted: Thu Jun 17, 2010 3:36 pm
by JT191
PR91 wrote: honestly guys, this has all been done before, with the hard work of designing and fab'ing the caliper brackets done too, so why try to re-invent it??
I'm new to this obscure corner of the already obscure Isuzu world, but not unable to operate a internet search engine. I've not found much of anything in the English speaking world as far as people selling performance or even replacement parts for Belletts. Who's selling brake kits or brake kit parts?
Posted: Sat Jun 19, 2010 7:06 am
by RobSA
Thanks Brett.
Thanks for the info on the different stub axles, can add that to the bank of Bellett knowledge :D
Posted: Sat Jun 19, 2010 4:51 pm
by JT191
Posted: Sun Jun 20, 2010 10:34 am
by PR91
RobSA wrote: Did you need the booster because of the different pedal ratio, or just a function of the master cylinder to piston area?
no probs rob.
Posted: Sun Jun 20, 2010 10:46 am
by PR91
JT191 wrote:I wasn't trying to be ignorant about it, but short of someone selling the exact piece needed, or a set of documented step-by-step instructions, just about everything we do for a Bellett or any Isuzu car is or is close to starting from scratch.
exactly JT.
Posted: Wed Jun 30, 2010 4:36 pm
by JT191
Posted: Tue Mar 01, 2011 2:25 am
by JT191
