Author |
Asroc66
Ok Guys Now please refrain from laughing but..... Has anyone got serviceable GT brake Pistons that they are willing to part with Out of 9 I scrummaged so far only 1 is useable So I need 3... Also need a set of dust boots as per photo Can anyone help Thanks J
Wed Sep 09, 2015 5:40 am |
67GT
Hi James, Not sure about the rubber boot, but I would think a good machine shop could spin up some new pistons for you.
Wed Sep 09, 2015 5:45 am |
Asroc66
Hi Thanks for quick response Am wondering if this is uncharted territory or has someone been down this road already? If so then could someone please give me details of shop, cost, how well they worked etc Difficult to find someone with such talent locally J
Wed Sep 09, 2015 6:05 am |
Give my mate Glen Hunt a call 3889 6669 (is his work number, Stainless Steel Sleeving, Brendale, QLD) He should be able to point you in the right direction, may posiblely machine up himself.
Wed Sep 09, 2015 8:11 am |
Asroc66
Thanks Stickman I was thinking the best way was to sleeve.... Surely this must be the case The Pistons are quite complex in nature Cheers J
Wed Sep 09, 2015 8:31 am |
PR95
Hi James, I used Jaguar Pistons in mine, check my post in the brake section on this site. Geoff
Wed Sep 09, 2015 10:44 am |
BHSS in Brisbane some they made the first set they machined and chromed them. So you have options.
Wed Sep 09, 2015 10:53 am |
Asroc66
Thanks guys So it it possible to sleeve? Or machine down and re-chrome ...... Wondering how this option effects the central Pin clearance etc Thanks J
Wed Sep 09, 2015 11:01 am |
pr95's jag ones have no pin and seem to have no il effect. They were done by a professional brake repairer.
Wed Sep 09, 2015 11:02 pm |
Asroc66
Spent the morning on the phone and ended up visiting local brake, clutch, machine / fabrication shop Left them a sacrificial piston to de-construct and estimate cost of fabricating with central shaft in stainless Will let you know if doesn't cost one's 1st born J
Thu Sep 10, 2015 8:55 am |
Asroc66 wrote: Spent the morning on the phone and ended up visiting local brake, clutch, machine / fabrication shop Left them a sacrificial piston to de-construct and estimate cost of fabricating with central shaft in stainless Will let you know if doesn't cost one's 1st born J In the past, I had a number of these pistons re hard chromed and then machined. Unfortunately, the guy who did them passed away but there must be some body who can do them. As for the rubber seals. I might still have a NOS kit here. Problem is finding it at the moment, since we moved house, nothing car wise has been unpacked. BGT brakes in Dandenong, Vic. can overhaul the calipers. (03) 9792 2806) Ain't cheap, about $500/pr i think it was. Or maybe $250 pair, I can't recall now. Call them...... they know Belletts. Most of BCCV go there. Pretty sure they use Jag stuff in them. They look like brand new when you get them back.
Thu Sep 10, 2015 9:42 am |
Asroc66
No problem with Calipers It's all about the Pistons Apparently because the seals are seated in the Calipers and not the Pistons means the Pistons are sacraficial J
Thu Sep 10, 2015 9:47 am |
Asroc66 wrote: No problem with Calipers It's all about the Pistons Apparently because the seals are seated in the Calipers and not the Pistons means the Pistons are sacraficial J BGT overhaul the whole thing. I imagine water in the fluid is the final enemy of the pistons as they start to corrode the hard-chrome. All of the pistons i got re-done were usable. The guy ground them back to base metal, hard chromed them and then re-machined back to size. I organised about 6 sets i think at the time for BCCV members.
Thu Sep 10, 2015 10:07 am |
1968GT
Brakes still good to Glenn, no misting around the calipers, no leaks and disc's are fine, all thoroughly checked before Toowoomba .
Fri Sep 11, 2015 5:00 am |
Asroc66
Hi Guys Dropped a set of pistons off with specialist Ceramic Coating Business They will take a look If pitting not to bad may be able to help] They do some weird and wonderful treatments on all sorts of parts for Tassie Targa cars including Jason White's Lambo......... Will let you know Cheers J
Mon Sep 14, 2015 4:26 am |
Asroc66
Spoke to Todd at Ceramic Coatings Tasmania this morning. He is confident he can coat a set of Brake pistons with this space aged NASA product. He has a coating for everything....... Opens up a whole new world especially to those 'Boy Racers' amongst us Will keep you informed J
Mon Sep 14, 2015 11:23 pm |
called into better brakes southport to see how my front brake arrangement was going he has it all apart and is also coating the pistons or whatever said he will fit some other valiant or whatever bits to it hes confident will let you know the outcome cheers davo the guy at better brakes is wayne number is 07 55710271 or 0400006340
Tue Sep 15, 2015 3:06 am |
Asroc66
I may have said this before but the thing about Bellett Brake pistons (which they did indeed pinch the design from Jaguar - Dunlop) is the central pin Apparently its function is to limit movement or 'knock-off' of the piston/pads when you take your foot off the brake thereby reducing pedal travel This is the main reason I am trying to resurrect the existing pistons rather than finding different pistons and machining them to fit Cheers J
Tue Sep 15, 2015 3:31 am |
Asroc66
Well have some information http://www.powertrackbrakes.co.uk/wcylinder.htmlThe front pistons are off the Jaguar 420G saloon built from 1966-1968... small run which makes then rare in itself Calliper Rubber Kit : Girling SP2565 Brake Pads Bellett : DB704 (No longer available - save your backing plates and have them re-bonded) Cheers J
Tue Sep 29, 2015 10:10 pm |
Asroc66
Just picked up the pistons from the Ceramic Coaters
3 are definitely useable, 4th touch and go as likely to 'seep' which may be OK on weekend driver but not daily driver so I will give it a go.......
Interim step to Sleeving if pitting minimal at about 1/3 cost........
Cheers J
Wed Sep 30, 2015 12:26 am |
