Front Indicator Lense 67 GT Bellett
flying
Post by flying »
I am chasing 1 white glass bee hive lense for the GT
Any clues of where to source
Regards
KJB
Re: Front Indicator Lense 67 GT Bellett
Post by KJB »
Looking for a couple myself - - this on EBay ( Item - 380193060716 ) caught my eye , might be a good option until correct lens turns up. Probably need a little modification but should not be expensive and is readily available.
Post by gt orphanage »
Another option is the later style pr90 set up. You can't get them but i got a set of toyota one that are the same from japan.
If someone has a parts book i need a part number i will see if it can be got out of japan? btw if you need the hole assy they are left and right.
Post by BULLITT »
hi greg PART NUMBERS ARE
THE BEEHIVE LENS 8262-1253 THEN HAS (AP20-00002)
UNDER DESCRIPTION EXPLODED VIEW 8262-0197 FLASHER LAMP ASSY R.H. (AF101-8)
8262-0198 L.H. (AF101-7)
CHEERS DAVO
Post by PR91 »
i'll double check before anyone commits to buying them, but i think good ole morris minor indicator lense are exactly the same type.... but only if u can handle having the word "lucas" on a bellett. they are readily available.
let me verify this first tho, and i'll re-post.
i will sit back until i know they want them before we chase them then thanks Brett.
KJB
Post by KJB »
I thought that I needed 2 but I have just found them. Mini minor lenses look like they may be a good option for anyone wanting lenses.
flying
Post by flying »
I had a spare with Lucas on it -- Almost the same slightly smaller diameter but you could make it fit if nothing else was available
