View unanswered posts | View active topics It is currently Thu May 28, 2026 11:05 am
Reply to topic  [ 17 posts ]
GT Parts needed
Am starting my GT resto so just putting it out there if anyone is willing to part with any of the following, let me know......after you get back up off the floor
Tacho
1600 head gasket
extractors
exhaust gasket
Craig
Wed May 30, 2012 6:26 am
might be a tough ask for some of those parts.
Jason has a few Bellett parts in another thread in Japanese auctions. Keep an eye on that, some of the bits might turn up.
I think i have a s/h exhaust gasket somewhere.
The BCCV used to have Gasket kits but i think none left although possibly that might change if they find/get made some more..
Wed May 30, 2012 6:52 am
head gasket repco part no is cj151 acl brand it is a valve regrind set with tappet cover gasket ect for a luv. manifold gasket is not going to work.
I have manifold gaskets made they are $40 each i am out at he moment but another ten are being made.
extractors are on the go too i have a luv 1 made for the race car and the gt gasket and manifold are going down next to lazer cut the plates soon. i only got a call yesterday to say the luv plate is done.
Wed May 30, 2012 8:07 am
my enquires down here for that set have shown no stock. Only the valve seals are still available.
Wed May 30, 2012 9:21 am
We got a few sets a couple of weeks back, let me know if you have no luck we have a contact at acl ;).
Wed May 30, 2012 9:46 am
Don't need one but was there getting other stuff so thought i would ask
BCCV though should get a few
Wed May 30, 2012 9:53 am
mate how did you lose the tacho or did it die ? have seen them come up on the o/s look what we have market place cheers davo
Wed May 30, 2012 9:55 am
If it's only dead otto instruments put a new guts in them past experience is they are wired wrong you have to swap the two wires around the tacho overides the points a she no go :o .
Wed May 30, 2012 10:00 am
is the 1500 head gasket the same as the 1600?
Wed May 30, 2012 10:06 am
they would be in the bore size but i use them on 1500,s
Wed May 30, 2012 10:09 am
Car didnt come with tacho or extractors, Was sitting on a farm for about 7-8 years. Had back windsceen smashed by vandals. tacho was either stolen or was placed by owner in one of his 6 or 7 sheds, unlikely to ever be found again in my lifetime. Likely there will be other parts missing as I progress but these are the most obvious peices at the moment.
Wed May 30, 2012 11:06 am
I have a tacho from a 117, the same as GT. don't know what condition it is in, if you are interested pm me
Geoff
Wed May 30, 2012 12:22 pm
had to make a set of extractors a few years ago for mine.
originals are over 40 years old now, and 90% are stuffed. my originals were waffer thin, and was a never ending job to patch them up, so i made a brand new set instead.
should be ok for another 40 years.
Fri Jun 01, 2012 11:08 am
did ypou make yourself Brett or get them made ?
Fri Jun 01, 2012 11:13 am
me Glenn. but did it in a mates exhaust shop when he still had it.
used the original mounting plate, but all new pipes and now a flat, bolt on flange to the exhaust, not a slip joint.
not that hard to do, and i'd still do my own even tho he doesn't have the shop anymore, but with bends and straight pipe sections u can buy separately, because a good exhaust shop with A: someone who cares, and B: someone who actually knows how to do custom work as opposed to "bolt off, bolt on" is getting bloody hard.
there are some around that do very nice work, but they know how to charge too....
mind u, my standards of what i'll except as a good job is probably higher than some, so i can be critical sometimes.
Fri Jun 01, 2012 11:26 am
yes, i have done one myself using U bends when i had the 1600 DOHC toyota motor in the white GT. Tedious but easy enough to do.
Not much choice though, toyota in a bellett, no off the shelf stuff LOL
Fri Jun 01, 2012 11:35 am
bellett in a bellett (ie: original) and there no off the shelf stuff either...
:lol:
Fri Jun 01, 2012 11:02 pm
