Sway bar end rubbers ?
1968GT
Re: Sway bar end rubbers ?
Oz,
You comin to MERIMBULA AND BRINGING SOME WITH YOU, I am in for a set or two!!
oz_toffa
not this year, Dave. just a bit too much going on with house hunting and weddings etc etc
but i am hoping to have it setup within the next 6 months to be able to produce enough to keep the Bellett faithful in stock for their cars.
cheers
cheers
1968GT
OK Oz, I know what that is like, keep us in the loop, no doubt you will!!
oz_toffa
rubbers arrived today. thanks very much farmer
they are now in a Mold of clay and Max 30, being kept at a temp of 27 degrees with my modified Willow cooler and should be ready for removal tomorrow at 6pm.
then some cleaning, spray lub and re-pouring should have the 2nd half on its way.
i will post up some pics of the first finished prototype once they are out of the Molds.
cheers
cheers
for some time i have been saving snippets of posts of interest, re parts: not sure who posted this but there is a number here for the end rubbers. Can anybody confirm it and if still available ??
pedders make universeal ones in urethane/nolathane.
inner sedan ones are part# EPH18.
GT are different as they are a couple of mm thicker in the bar, but i can't remember the exact size or part# atm... but i think they are 21mm. i'll check when i'm near my GT again.
outer ends are all the same, part# EP3320/15.
flying
- Car(s): 1967 GT Bellett
Yes they are available and you can use them red in colour standard D Bush --it will need the top scollaped out of it to mimmick the original $25
flying
Pair
oz_toffa
can you paint them black?
i have all my bushes in my 68 sedan replaced before i bought it and they work a treat but i personally think the red looks bloody awful. hence why i have gone down the path of making my own black replica bushes.
cause i would like it to look as original as possible. but others may like showing off their RED bushes. not me!!
thanks flying and glenn
not keen on red either but if that all one can find then thats it i guess. I think paint would come off pretty quickly though with the flexing
should be able to find the equivalent parts in super pro/fulcrum bushings which are a dark blue colour if you are trying to keep it looking more origional, my preference is for blacl bushes on the car, but that may not always be an option.
RobSA
- Car(s): BA Falcon, 68 Bellett
I might have to talk to you about them thar red ones when you go black.
Match my springs they might
oz_toffa
they would indeed!! it will be the first of my cars to have the new replacement bushes fitted. Shore hardness is very close to original bushes i supplied the Mold suppliers :0
yeah!!
yeah!!
Inner bar rubbers in blueoz_toffa wrote:can you paint them black?
http://media.superpro.com.au/SuperProCa ... 14.005.pdf ee the HK Holden area. Various hole types for different sway bar diameters available too,
alos they sell the material in rod form which might be usable on a lathe to make the rack mount rubbers.
APPEARS THE LINK ABOVE IS NO LONGER VALID BUT THE COMPANY STILL EXISTS:
https://superpro.com.au/bush-sizing
Here's an example of a search using 21mm ID.
TASSMAN
- Car(s): 67 bellett 1500 deluxe in restoration mode
fellow belletters in 2012 oz toffa showed a photo of swaybar rubbers he had moulded.can anyone tell me if they are still available?i require the end ones.i believe they are 15 mm.thanks.
