Waterpump off of 72 Luv for use on Bellett's
- Doug
- Car(s): 65 Bellett PR20; 66 Bellett parts car
It has been suggested that a waterpump of a Chevy Luv 1972 could fit onto a Bellett.
The LUV pumps are still available here in the US.
I had a request from oz_toffa who wants to try this out.
I ordered one and took some pictures which I will post here for a comparison.
Most of the bolt holes seem to match up and the actual pump housing is a very similar shape.
The outlet is in a very different place, but I would think a flexible hose would work.
I will leave it up to oz to actually try and fit it on.
I'll see how adept I am at loading up the pictures here.
Doug Hillmer
- Doug
Re: Waterpump off of 72 Luv for use on Bellett's
I forgot to mention anything about pricing.
This particular LUV pump I got was about US$32 (24 plus 8 for shipping to US address).
We have not yet ventured to see how much it is going to be to ship over the pond, but I suspect around as much as the thing cost.
Doug Hillmer
- Doug
This is both pumps side by side
- Attachments
- Both pumps side by side
- Side_by_Side_Waterpumps.jpg (68.93 KiB) Viewed 60070 times
Doug Hillmer
- Doug
This is a closer up of the original Bellett pump.
One thing to note is that between holes 2 and 3 in the picture there is another hole.
On my engine there is no bolt in that hole. I mention this because on the LUV pump (next picture) there is no hole there.
- Attachments
- Original pump off 65 Bellett
- Orig_65_Bellett_Pump.jpg (76.61 KiB) Viewed 60070 times
Doug Hillmer
- Doug
Here is the LUV pump. (Bomba de LUV in spanish, has a nice sound to it
Note the direction of the outlet.
Also note that hole 1 does not exist.
That may be the real sticky point, but I think it could fit still.
- Attachments
- New pump for 72 LUV
- New_72Luv_pump.jpg (82.06 KiB) Viewed 60070 times
Doug Hillmer
- Doug
One last picture here, there was a gasket that came with the new one.
I scanned a copy of it and hopefully this will come out as actual size
(print on 8.5x11 paper).
- Attachments
- New LUV gasket
- 72Luv_Water_Pump_Gasket.JPG (688.25 KiB) Viewed 60070 times
Doug Hillmer
- Glenn
- Contact:
I have a chev LUV water pump also here (at home that is) but it has a boss on the back area of the water outlet i think. Can't recall if Bellett has that also.?
- Doug
I had realized I also should have taken pictures of the backside.
While Glenn was busy replying, I was doing that.
Yes there is a hole in the backside of the outlet that would need to be plugged.
I suspect you could find or make something to screw in that would plug it.
(see pictures to follow).
Doug Hillmer
- Doug
Here is the backside of the original Bellett pump.
- Attachments
- Backside of original Bellett pump
- Backside_Orig_65_Bellett_Pump.jpg (79.69 KiB) Viewed 60065 times
Doug Hillmer
- Doug
Here is the backside of the LUV pump, notice it has a plate screwed on.
- Attachments
- Backside of LUV pump with plate
- Backside_New_72Luv_pump_with_plate.jpg (85.47 KiB) Viewed 60065 times
Doug Hillmer
- Doug
This is the backside of the LUV pump with the plate removed.
- Attachments
- Backside of lUV with plate removed
- Backside_New_72Luv_pump_no_plate.jpg (88.47 KiB) Viewed 60065 times
Doug Hillmer
PR95
Looks like 1800 sohc water pump to me
- Glenn
- Contact:
ala Chev Luv. I bought one the same recently off ebay.
- oz_toffa
thanks for all your help there, Doug.
may be able to use internal bearings and seals to repair the original Bellett pumps.
worth it for a job lot.
cheers
cheers
That was the pump I was looking at for the OHC motor sitting in the shed Oz.
Maybe I'll have to owe you money for two pumps
