Next project g200
gricey
Re: Next project g200
No it does not . I have dewers performance engines on the job . Wally dewer is one of the best and a personal friend . Gricey
gricey
Found out why it gave up . The g200 has two cams and normal cam shaft drives the fuel pump and the oil pump . The oil drive on the cam was completely worn out .lucky I have a new one. Looks like I also have to sleeve two cylinders . . And I have sent the cams to get tricked up . Also I am looking fo 2 40mm webers if any one can help that would be good . Gricey
- oz_toffa
Gricey, i think you and Bellettboys need to get together and have a beer or 2 to wash down your dead motor woes.
she sure looks pretty sad.
what series is the twin cam with the alloy blue timing cover?
gricey
No idear . Gricey
gricey
Anybody give me a contact to get wheels widened. Gricey
- Glenn
- Contact:
There's a couple of places down here. On my phone right now but try Google wheel repairs. Craig probably knows some too.
gricey
FIRST PHOTOS . THE FUN BEGINS . GRICEY
- Attachments
- GT 3 RESTO 001.jpg (650.27 KiB) Viewed 31708 times
- GT 3 RESTO 004.jpg (649.61 KiB) Viewed 31708 times
gricey
Tried to send more photos no luck . Car was last registered 1982 . I got it off bob Blackwell when I bought the red gt . Notice crumple right front chassie . But all is prity good. Gricey
gricey
I have most bits I think . Gricey
gricey
Ok car is fully striped. Two items I will need to source are 1 disk brake rotor and torsion bar . Quite happ to pay . Gricey
Gemini ZZ/R PF60Ewhat series is the twin cam with the alloy blue timing cover?
gricey
The body is ready to sand blast under in boot and engine bay . The only rust to repaiir is under front guards near the screen . Usual place . The g 200 has been re built just néed to get a head gasket . And timing chain tensions .and it's finished. Then the slow process of putting it all back together . The plan is taste 2014 . Doubt that I could make Adelaide .after restoring two cars I think this one will be spot on . Gricey
gricey
up date .started to put back to geather . rear end almost done, g200 has been re bult. now the fun starts . gricey
- Attachments
- Bellett GT 3 & Torana-jan 2013 001.jpg (1.28 MiB) Viewed 31370 times
i can help with the rotor if you still need 1. timming chains ect i have put part numbers on here 1 needs a few links taken out. do you have twin cam timing chain set up they are a interferience engine and will bend valves if not correct.
gricey
Greg . Yes I need a rota . Not sure about timing chain . The engineer has built the (g200 , gricey
gricey
I am planing to fit 2 40m webers . To the g200" they do cost a fair bit I have been on the look for some time no luck.. About two weeks ago about 3 am I was sitting in the lounge thinking . Alfa fit webers . Recall taking a Alfa out of a shed . Non payer . And dumping it down the back . Went to look . Yep 2 40m . Beauty . Gricey
nice score from the alfa!
- Glenn
- Contact:
any more updates, Gricey ???gricey wrote:I am planing to fit 2 40m webers . To the g200" they do cost a fair bit I have been on the look for some time no luck.. About two weeks ago about 3 am I was sitting in the lounge thinking . Alfa fit webers . Recall taking a Alfa out of a shed . Non payer . And dumping it down the back . Went to look . Yep 2 40m . Beauty . Gricey
