Elf and Safety
elfovernighter
- Car(s): 1965 isuzu elf
Elf and Safety
Was given this Isuzu Elf to save it from going to recyclers. Will give me something to keep me out of trouble
- Attachments
- DSCF3076.JPG (1.47 MiB) Viewed 78656 times
- DSCF3069.JPG (1.44 MiB) Viewed 78656 times
- KJB
Re: Elf and Safety
I like it - ALOT....
- Stickman
- Contact:
Re: Elf and Safety
It looks like a 'Donkey transporter'
- oz_toffa
Re: Elf and Safety
that's a RIPPER...............
be quite a few people who would love to have that in the garage
- bembokabellettbloke
- Car(s): not enough!
- Contact:
Re: Elf and Safety
Dennis had one like this BRAND NEW!!!!!
I got a tray built for it
WOW....Where are you elfovernighter?
- Contact:
Re: Elf and Safety
has it got dual rear wheels or single wheels?
elfovernighter
Re: Elf and Safety
A couple of more pictures, been busy finishing the interior of a 1980 caravan. Need it out of the way to concentrate on THE TRUCK. Just love the solid thunk of the doors when you close them, makes me all nostalgic. I am reliving a past life, obviously being repaid for leading such a wholesome life. (Yeah, right)
- Attachments
- DSCF3073.JPG (1.4 MiB) Viewed 78559 times
- DSCF3082.JPG (1.47 MiB) Viewed 78559 times
- DSCF3075.JPG (1.44 MiB) Viewed 78559 times
- DSCF3072.JPG (1.43 MiB) Viewed 78559 times
- DSCF3071.JPG (1.43 MiB) Viewed 78559 times
- dave
- Contact:
Re: Elf and Safety
Nice pussy.
Re: Elf and Safety
Down Fido !!
elfovernighter
Re: Elf and Safety
Truck started today, radiator holds fluid (no leaks), throttle cable needs replacing. Carby flooded (kit to go through it) Original sewn floor mats removed,Original windscreen washer bag still under dash. Clips on floor vent still work,lights and horn work, indicators don't. Very minor rust in floor, original vinyl on seats under felt covers.
- Attachments
- shabby controls
- DSCF3130.JPG (1.46 MiB) Viewed 78465 times
- rusty floor
- DSCF3128.JPG (1.48 MiB) Viewed 78465 times
- washer &vent
- DSCF3129.JPG (1.47 MiB) Viewed 78465 times
- squabs still have original covers, very dry and brittle
- DSCF3131.JPG (1.4 MiB) Viewed 78465 times
- original mats stitched together???
- DSCF3126.JPG (1.49 MiB) Viewed 78465 times
- 1968GT
Re: Elf and Safety
This would be a unique, cool
restoration!
elfovernighter
Re: Elf and Safety
Another successful day, and thank you to the expert passing by who told all about my 6 cylinder chev built Isuzu that was imported into Australia by American Motors prior to them building Isuzu Bedfords which were also built in America. I still cant find those other two cylinders though(beginning to worry). Have moved it where it can't be seen from the street. Stripped the seats out ready for the motor trimmer. Gave the cab a good vacuum out (some women are funny about thier Dyson's, they are made to vacuum up crud.) Drivers seat is 75 mm wider than the passengers and has extra padding in the squab, no end to the luxury provided.Took a good 3 hours to remove the left rear brake drum, full of dirt and wasp nests. Just persevere and a pressure hose got me there. Front left, both slave cylinders leaked , rebuild or replace. Left rear looks like relatively new cylinders. Brake and clutch pedal/master cylinders out for clean up and rebuild. One unusual storage "can" fed both master cylinders. All coming along nicely and am enjoying the job, feeling quiet "fond" of THE TRUCK. Kicking back with a coffee and a couple of chocolate digestives, feeling good about my progress. (don't get to smug)
- Attachments
- Looks like new cylinders
- DSCF3144.JPG (1.44 MiB) Viewed 78395 times
- L/R Brake
- DSCF3143.JPG (1.48 MiB) Viewed 78395 times
- Storage for jack etc. behind drivers seat
- DSCF3140.JPG (1.4 MiB) Viewed 78395 times
- Cleaned out
- DSCF3141.JPG (1.42 MiB) Viewed 78395 times
- L/F shoes
- DSCF3138.JPG (1.41 MiB) Viewed 78395 times
- Seats and door trim
- DSCF3139.JPG (1.41 MiB) Viewed 78395 times
Re: Elf and Safety
your doing agreat job and I did spot the crankhandle a great find keep at it we are all watching you ..and farmer and benboboka and dennis know all about these gems cheers davo
Re: Elf and Safety
I have Elf envy! you know that you can use other house hold stuff to help clean, i have used the dishwasher more than once to help clean alloy stuff! (dont tell my wife though!)
looks like you are getting it sorted it will be cool to see it out and about in the future.... might have to keep an eye out on the farms for one!
- KJB
Re: Elf and Safety
Project is off to a brilliant start
- 65bellett
- Car(s): 65 and 66 sedan
Re: Elf and Safety
Great to see you getting cracking on the resto. You should have it ready in time for the Bay to Birdwood
Keep up the photos I know I can't get enough of them.
- dave
- Contact:
Re: Elf and Safety
There is a bizarre mix of familiar and unusual stuff in there. That handbrake lever looks familiar at the very least!
Also weird what works on an old machine... I seem to constantly have troubles with my horn (no jokes please)... but the horn on this works just fine!
Re: Elf and Safety
I have never seen 1 of these in the flesh. I don't want to sound like the dude that knew it all either, but have a look at the us ebay and see if some brake bits are chev luv not being funny here but some of the wasp and luv stuff are the same.
elfovernighter
Re: Elf and Safety
The more I delve into THE TRUCK the more finicky little quality detail I find. The throttle linkage under the cab is a real work of art as are the gear linkages. Must have taken some time and effort to install. Discovered a 12 volt power outlet under the dash(work light outlet???) The windscreen washers are worked by a manual hand pump down the right hand side of the steering column. Lever operated radiator drain on the cowling of the radiator, saves getting under to drain it. Still has the writing on the washer reservoir bag. Got back brakes active along with handbrake. Still sanding and de-scaling bits and pieces. Am have some luck chasing parts that cross over from other early Japanese vehicles. LandCruiser used the same clutch slave cylinder.
- Attachments
- Very clear instructions
- DSCF3150.JPG (1.38 MiB) Viewed 78327 times
- Washer fluid bag
- DSCF3151.JPG (1.43 MiB) Viewed 78327 times
- Manual washer pump
- DSCF3153.JPG (1.44 MiB) Viewed 78327 times
- Power outlet
- DSCF3149.JPG (1.43 MiB) Viewed 78327 times
- Main fluid reservoir/brake & clutch
- DSCF3146.JPG (1.41 MiB) Viewed 78327 times
elfovernighter
Re: Elf and Safety
Dismantled engine covers removed radiator and gave everything a bit of a clean up then I noticed some pieces didn't fit quite right. Some brackets were not in use anymore and some cables and wiring looked out of place. On closer inspection and a bit of sleuthing I discover THE TRUCK is fitted with a 2R motor from another Japanese builder of vehicles. Bit of a re-think about which way to go now.
