Water pumps
Re: Water pumps
Stanmore Auto Services has been cleaned out!
All the water pumps went to Australia and I am told there is no longer any in New Zealand
Re: Water pumps
Hey guys,
A friend of mine managed to track down another water pump. It's a NOS pump made by GMB.
The Part number for this is GWIS-13a like the ones stanmore autos had in stock. But it says it is for a G161 engine.
Can anyone confirm if the G150 and G161 share the same waterpumps?
- bellett65
- Car(s): Isuzu DMax LSU, Isuzu MUX, 1979 117 Coupe.
Re: Water pumps
Try this site they have a PDF file with pictures of the pumps. It does look close from my memory.
http://www.kingleadtrade.com/catalogue/ ... st2007.pdf
This is from NUTEK site
http://www.nutekpart.com/productContent.asp?ID=258
FASTER 1600 72. ~76. KB-20 G-161 GWIS-13A 9-13610-319-2
76. ~80.10 KB-20 G-161Z GWIS-01A 8-94202-477-1
Re: Water pumps
just handed to me (literally 2 minutes ago!) by 'toomanybelletts' is a rebuild kit for the 3 bearing engine.
brand is: ASAHI.
part no: "kit" R-200.
to suit: bellett gasoline. 1964-66. PR10 & 30, KR10, KR10V (G130). PR20 & 80 (G150).
box is green and red, with white writing.
came via yahoo auctions in japan. approx $80 plus freight.
also shown on the box is another part no, stating "pump" P-200.
while this is for the early engine, it gives a starting point (ie: brand name, part number reference, look of the box, etc) to chase details for the later 5 bearing pumps and/or rebuild kits as well.
brand is: ASAHI.
Re: Water pumps
I have 2 waterpumps on the way to australia when they arrive and it is confirmed that they fit?i will pass the info on.
Re: Water pumps
waterpumpwharehouse on ebay motors usa isuzu l4 forklift g150.
Re: Water pumps
I learnt today the differance between the water pumps backing plates.The plate on the back of the pump in the 5 bearing engine bolts complete with the plate supplied to the block.In the wasp 3 bearing the block has a plate the sits behind the timing gear that bolts to the block this plate also is used for engine mounts,generator as well as the water pump backing plate.We will remove the plate supplied with the pump and bolt it on to Walter the wasps engine plate.
- BELLETTPR10
- Contact:
Re: Water pumps
Digging up old posts
- Attachments
- Bellett Engine 067.jpg (116.02 KiB) Viewed 58404 times
- Bellett Engine 068.jpg (114.16 KiB) Viewed 58404 times
- Bellett Engine 074.jpg (104.54 KiB) Viewed 58404 times
Re: Water pumps
there was a company in the us called the waterpump wharehouse thye sold waterpumps for a g150 forklift. This may be a lead or someone may have parts for the forklifts? 1 would assume that they have g150 engines
- BELLETTPR10
- Contact:
Re: Water pumps
Mark
Mark
gricey
Re: Water pumps
Hi . I just took hy old. Pump to Bursons . The got them re built . Gricey
gricey
Re: Water pumps
My daughter in law runs spare parts for a fork lift company . I will let you know what she finds out . Gricey
Re: Water pumps
hi guys just in case I have a g161 flo motor will the kb20 luv(76-81) fit it ?? looking in the future cheers davo
Re: Water pumps
Davo I don't think so it is only the early luvs.
- oz_toffa
Re: Water pumps
not if its the G161Z motor (same as the gemini)
you will need a waterpump that fits early Chev Luv 1972-1975
like this one!
http://www.ebay.com.au/itm/CHEVROLET-Lu ... 8d0&_uhb=1
like this one!
Re: Water pumps
HI GUYS I AM A MUSO (SO CALLED).... SO THE 1600 G161 MOTOR (BELLETT /FLORIAN) MOTOR THE WATER PUMP WONT FIT ?? JUST THAT IF THEY WERNT READY AVAIL ?? THOUGHT ID GRAB ONE ..............WHAT DO I DO ??? DAVO
PR95
Re: Water pumps
Buy the oz toff ebay one, that will fit your car.
- Glenn
- Contact:
Re: Water pumps
that company also has points, caps, rotors for various Isuzu modelsPR95 wrote:Buy the oz toff ebay one, that will fit your car.
http://stores.ebay.com.au/Powerflow-Per ... =148246526
degruch
Re: Water pumps
Has anyone fitted an Asahi R200 pump? They look totally different to a standard G150/G161 pump, so I'm hesitant to hit the 'buy now' button on Import Monster. Are they suitable?
- oz_toffa
Re: Water pumps
a link to the pump on the site would make it easier to give an opinion.
i looked for 15min before giving up!
