View unanswered posts | View active topics It is currently Fri Jun 26, 2026 11:04 am
Temperature Gauge
Hi Guys,
I am having trouble getting my temp. gauge to work in the Wasp. I have power to the wire, I have had the gauge recalibrated and fitted a new sender unit to the head.
The only thing I can think is that I have a wrong (or faulty ) sender switch ? Has anybody replaced one recently and have a part number ?
Mon Feb 10, 2014 4:01 am
67GT wrote:
Hi Guys,
disconnect the sender and ground the wire. does th e meter read anything then ? If so its the sender most likely. If not either the wiring or guage
IMHO
Mon Feb 10, 2014 5:23 am
Hi Glenn,
Yes, that's what happens. I have just picked it back up from the sparky's, he's had it for a week, and it still doesn't work.
Do you know where to get a suitable sender ? As I believe they are all have a different resistance.?
Mon Feb 10, 2014 6:31 am
Car(s): BELLETT SEDANS X 3
G'day 67GT
Pm me your telephone number and I shall give you a call regarding sender units the BCCV have in stock. Cheers Steve
Mon Feb 10, 2014 7:06 am
Normal Holden Gemini senders work with Bellett/Wasp gauges.
Both oil and temp.
Readily available.
Mon Feb 10, 2014 8:02 am
67GT wrote:
Hi Glenn,
If you ground the wire, then the temp meter should go to full scale (ie HOT)
If not then I would be checking the wire back to the gauge and also, check if 12v is present when the sender is disconnected. ie you need a hand held voltmeter and connect it to the wire and ground. You need ignition key on of course.
That will tell you that the 12v is connected to the meter and also that the wire is good. A test light will most likely not work for this test though, you need a volt meter.
If that test fails you will need to pull out the gauge panel and check if there is 12v going to the meter. Possibly a bad connection in the wiring plugs too.
Bellett Car club has the Temp. sensors in stock. (not a big seller) Technically you should be a member of BCCV to buy parts (perhaps you are) but I am sure the committee can over ride that for you.
Mon Feb 10, 2014 9:54 am
Thanks Glenn,
I will try and get hold of a volt meter, as I have been using a test light. I guess if the voltage isn't high enough it will not read the switch properly ?
Tue Feb 11, 2014 9:02 pm
silly question is the sender earthed :?: Thread tape ect between the sender and head will not allow sender to earth :?: A test light between positive and the nut part of the sender will confirm.
Tue Feb 11, 2014 9:10 pm
67GT wrote:
Thanks Glenn,
If you remove the lead and test, you need a voltmeter. A test light has too low a resistance to properly check the circuit through the meter back to the battery supply in the dash.
the post below re ground is valid although it would be unusual i think to lose ground after the sender was there for so long. But stranger things have happened to worth checking also. [the sensor inside the housing may have become detached from the case]
If you get a voltmeter, it will also have a resistance checker which can be used to measure the resistance across the sender (with the lead removed)
I don't have resistance value available but if you get a meter, i can check mine for you.
Tue Feb 11, 2014 9:40 pm
Perhaps not such a silly question GT Orph.
I will go and check that today.
Tue Feb 11, 2014 11:10 pm
Ok no thread tape. That would have been too easy.
I have ordered a new switch from Bursons, to suit a Gemini (based on Brett's earlier post) but will have to wait until tomorrow for it to come in. Hopefully it is just a faulty switch.
Wed Feb 12, 2014 12:09 am
Fri Feb 14, 2014 4:18 am
Sorry Dave,
We have been a little busy at work and I haven't had a chance to try yet
Fri Feb 14, 2014 4:58 am
Sat Feb 15, 2014 1:30 am
Sat Feb 15, 2014 1:34 am
How B..... frustrating!
It was interesting the information from Brett that the Gemini are the same senders for water and oil.
What is the contact like between the wire and the sender? I fixed my issue by tightening the connection.
Sat Feb 15, 2014 2:09 am
did you try shorting the wire to earth ?
.......with ignition on of course.
I measured the resistance of my Sport sender with the lead disconnected and it is 430 ohms. Engine cold.
I ran the engine for a short time until it got to about 70C and the resistance was 60 ohms. again, wire disconnected
These are rough numbers only as each sender will be a bit different but what it shows is the resistance is falling as the meter rises up the scale.
Shorting the wire will then give maximum meter reading. ie VERY hot!
Sat Feb 15, 2014 4:48 am
I don't knowmif it will help much, but I've found that a dull film on brass contacts can cause intermittent failure of circuts. Take your dremmel multitool type machine (mine is Ozito, $50 from Bunnings) and thoroughly clean up all contacts until they shine, even if they look pretty clean. This film was once the cause of my Doris having an intermittent miss that eventually prevented her from starting.
Do the whole car - coil, dizzy, relays, everything. All the slide connectors, including the back of the fuse box. It takes some time, but only needs doing every 20 or so years.
Hope you get it sorted,
cheers, Matt.
Sun Feb 16, 2014 11:56 am
I took the Wasp out yesterday ( thought I might pick the young bloke up from school--didn't he love that :D ) to give it a run and see if the new sender had made any difference. It does seem to bounce up to a reading every so often, but doesn't hold any position for too long. So it is trying to work. Maybe Farmer is onto something.
I also found out that Wasp's don't like rain. :( As I picked him up from school, the heavens opened up, which isn't good when the wipers fall off the spindle !! :o
Light weight alloy trays aren't very good for rear traction on utes either. :twisted:
Wed Feb 19, 2014 10:17 pm
partially good news then, the system 'can' work. Certainly sounds like an intermittent connection.
Wires in a Bellett often harden up and crack or break from the heat of the engine too over time.
Wed Feb 19, 2014 11:02 pm
