GT from Australia in "Good" condition.
Re: GT from Australia in "Good" condition.
otto instruments did mine in brissie. for some reason the are back to front
when you refit them if the car will not start swap the 2 wires.
- Glenn
- Contact:
this is the one i have. On reflection, it probably does not work.
- Attachments
- tacho_pcb.jpg (145.76 KiB) Viewed 14885 times
- Glenn
- Contact:
There are two transistors used in the circuit. There could be anything wrong with the Tacho parts though.gt orphanage wrote:otto instruments did mine in brissie. for some reason the are back to frontwhen you refit them if the car will not start swap the 2 wires.
http://www.ebay.com/itm/2SC282-Original ... 0405083014
Gunna
Should we start a new thread on "tachometer repairs"??
But there is no "electrical/electronic" section.
GerryBellettGT
- Car(s): Bellett GT,
Congratulations on once again becoming a GT owner,must be a buzz having your old car back.
I had my Tacho's guts pulled out,replaced with modern,same front,by Geoff Wright 0755206509
works from home Palm Beach,100 or 150$ left it with him one weekend pickup the next,very happy
with the results Gerry
Much better option Gerry cheaper too.
well done nice looking gt ...is it off to Tassie cheers davo
Gunna
No. Love to go down and do a spot of holidaying but business calls. Maybe 2015 if its somewhere north.BULLITT wrote:well done nice looking gt ...is it off to Tassie cheers davo
you may live real close to 2015 at this stage
