Like Donkey's
My 74 Chevy Luv
- Stickman
- Contact:
Re: My 74 Chevy Luv
Leave it CRUSTY!
Like Donkey's
Like Donkey's
- pa_man
Re: My 74 Chevy Luv
I polish my crust!!
- redback
- Contact:
Re: My 74 Chevy Luv
We only have buffalo skull up here in the nt, not sheep skulls, and I don't think my visor will hold the weight........
- Anthiron
- Car(s): 74 Chev Luv, 60 VW Baja Bug, 72 MK1 Escort, 70 MK2 Cortina, 04 Harley Sportster Custom, 79 Yamaha RX125 Tracker,
Re: My 74 Chevy Luv
Its been a while since I was on here!
Couple of new pics of the Luv
I am going to be supercharging the engine with most likely an AMR500 (just trying to find a decent one for cheap). I have a 45mm DCOE Weber to use with it.
Idea is to run the SC just forward of where the stock carb sits and the side draft weber on a 90 degree home made manifold. If I run a 2:1 pulley it should see around 8psi max and this will keep the unit under its 16000rpm redline.
Anyone have any tips or ideas here? It will be a big trial and error system for me currently.
- Glenn
- Contact:
Re: My 74 Chevy Luv
I think this is same type? On a Corolla. Might give you some ideas on mounting perhaps.
- Attachments
- 20141207_095753.jpg (321.62 KiB) Viewed 30062 times
- dave
- Contact:
Re: My 74 Chevy Luv
That's such a cool truck!
- Anthiron
Re: My 74 Chevy Luv
Interesting snout setup to line up the pulleys. To be honest I have put the supercharger idea on a bit of a back burner while I work on my Cortina but still keeping an eye out for an AMR500 cheap.Glenn wrote:I think this is same type? On a Corolla. Might give you some ideas on mounting perhaps.
