Spotted a GT cruising North bound
Got a joke you want to share? Or a picture so hilarious you have to show someone or you'll die? Share here but keep it (relatively) clean!
Re: Spotted a GT cruising North bound
Post by Stickman »
A good plan and pants with very deep pockets :lol:
gricey wrote:Davo . Take some good advice . Don't strip to Mutch off untill you get a good plan . It's easy to pull apart mate . .gricey
I agree with that too, you will also end up with a lot of parts to store. Best to plan it as much as possible
Post by BULLITT »
hi glenn ,gricey and stickman...I had to take of the gaurds and doors to see what rust it has ....so off come the front valance as well bumpers came off to totally soak with penetrating oil to save the rubber overriders ...seats came out as they need re foaming ..2 slight tears ..I will get some quotes while they are out ...the car seems reasonably sound ..I am not scared of this one yes it has a few holes ...plastic was still on rear quarters over the trim which is mint ...glenn I do need adrivers side kick plate its pretty r/s do you have any spares ?? ...so yes I have a plan I have boxed all the parts taken off so theres no confusion ....i have come to a woa back ..till its assessed cheers and thanks for your kind comments cheers davo
Retroasted
Post by Retroasted »
Sandwhich bags are good too the ones with the zip lock things. The write on masking tape and stick it to the bag to label where the bolts, clips, screws, etc. Go
BULLITT wrote:hi glenn ,gricey and stickman...I had to take of the gaurds and doors to see what rust it has ....so off come the front valance as well bumpers came off to totally soak with penetrating oil to save the rubber overriders ...seats came out as they need re foaming ..2 slight tears ..I will get some quotes while they are out ...the car seems reasonably sound ..I am not scared of this one yes it has a few holes ...plastic was still on rear quarters over the trim which is mint ...glenn I do need adrivers side kick plate its pretty r/s do you have any spares ?? ...so yes I have a plan I have boxed all the parts taken off so theres no confusion ....i have come to a woa back ..till its assessed cheers and thanks for your kind comments cheers davo
Do you mean the aluminium side plates along the bottom of the inside sill area? I have seen them eroded badly and would be hard to replace unless somebody has some tucked away from a wrecked body. Bent etc could be carefully straightened. Possibly with a soft hammer. None here I am afraid. (need to put the Sport ones back in too, once carpet is done)
rod
Post by rod »
Retroasted wrote:Sandwhich bags are good too the ones with the zip lock things. The write on masking tape and stick it to the bag to label where the bolts, clips, screws, etc. Go
also take photos if u can too mite help ...... bag n tag screws good idea ...done that before
Post by BULLITT »
yes glenn that's them I will persevere with a light hammer then buff polish them up ...ah another little job ...what sort of $$ for a set of carpets allowing for the tunnel bits ....which have to be specially made ...hey another thing these bucket seats also tilt as well as fold down .....im learning daily .....rear quarter windows came out to check rust and sometimes rusted hinges ...great all as good as gold .........cheers davo
Post by gt orphanage »
I told you that the seats may tilt and fold ;) Remember
Post by BULLITT »
hi guys as promised ...call me crazy but I let my blue teardrop go .....I did love it however when this little gem came up I had to do some serious juggling ...in the mind and in the finances ....what do you think aint she a beauty ...cheers davo oh I have the radio ..tyres are perished they are 35 yrs old ...
MOTOR PASSENGER SIDE.JPG (1.85 MiB) Viewed 27402 times
REAR SEAT.JPG (1.27 MiB) Viewed 27402 times
FRONT SEATS PASENGER SIDE.JPG (1.74 MiB) Viewed 27402 times
INSIDE DASH.JPG (1.54 MiB) Viewed 27402 times
redback
Post by redback »
Nice work - I am soooooo jealous mate!
BULLITT wrote:yes glenn that's them I will persevere with a light hammer then buff polish them up ...ah another little job ...what sort of $$ for a set of carpets allowing for the tunnel bits ....which have to be specially made ...hey another thing these bucket seats also tilt as well as fold down .....im learning daily .....rear quarter windows came out to check rust and sometimes rusted hinges ...great all as good as gold .........cheers davo
Proceed slowly though, or you will stretch the aluminium. Use some thing soft to support the pieces on when you use the soft hammer. ( a bit of carpet for example) In fact, that alloy is soft as it is, a lot of the minor dents etc usually can be removed by using your hands/fingers.
The car in pics looks pretty nice. Nothing major in the panel area by the look of it. Some rust as you know. Take your time Dave. Tackle a bit at a time.
flying
Post by flying »
Davo
Love the interior looks in good nick
One thing I did with the floor was to scrape out the seam seal -- it looked fine but it hid surface rust underneath the seam seal -- its old clean it up and reseal.
Carpets - I had a quote from Whilshires here $400 - they strongly recommended to bring the car in (one of the last things you do)as goning on the pattern of old shrinking carpets is not a good idea as they were a loose fit from new.
I unfortunately didnt heed their advise and have a loose badly fitting carpet.
I will take a photo of my exhaust with the original tail section similar to the first pictures you have.
Also agre with other comments - Lots of Photos and bag everything
Well Done Looks Great
Cheers Flying
Post by Farmer »
:shock: WOW! Davo, that is a beautiful thing. I believe you have made a very good choice. Most of us will never have the chance to buy a PR90, particularly in this condition.
Has it been resprayed in the past? If not, I would be doing only the minimum work to fix any rust, and just touch up. I know, I'm an originality freak, but I've been reading Survivor Car Aust. mag, and believe that as original as possible will be the most valuable. It also consumes less hard earned.
"They're only original once!"
Good to see you're straight into it, most important thing is to get it on the road & go cruising with your mates, and some of them up there will be a great help, no doubt. Go carefully mate.
Very congratulations!
Cheers, Matt. :mrgreen:
Post by Farmer »
Might be time to start a "My Bellett" thread, as this is definately "on topic"!
:D Matt.
Post by mrflibbles »
congrats on the awesome find! it looks pretty good, the cookie cutter style wheels are different!
GerryBellettGT
Post by GerryBellettGT »
Great to see another coming to the sunshine state,wow what a find,hope you don't have the rust Patches had,Lesley seems to think we talked to the owner of this car in Evans Head some 32yrs ago,where or when will the next one turn up :o you'll have to join osjcc now,it will be well talked about this weekend All Jap day Brisbane,Gerry
Early GT
Post by Early GT »
Yeah Gerry,
You'll have to pick him up on the way through. Hopefully you are not working Davo!
Post by BULLITT »
hi lewis im not working would love to go ......will contact Gerry ..cheers davo
GerryBellettGT wrote:Great to see another coming to the sunshine state,wow what a find,hope you don't have the rust Patches had,Lesley seems to think we talked to the owner of this car in Evans Head some 32yrs ago,where or when will the next one turn up :o you'll have to join osjcc now,it will be well talked about this weekend All Jap day Brisbane,Gerry
Nice plug Gerry old school Japanese car club will be at the all Japanese show this Sunday we will have around 15 club cars at this event. We cater or all old Japanese cars but there will be a fair show of Belletts. osjcc.com Soon to be linked with the bellettcarclub.com website.
Post by BULLITT »
see you sunday greg and lewis and anyone with a surname of isuzu .....davo
