CHOKE CABLE
CHOKE CABLE
hi I am chasing a choke cable for the 90 anyone got spares ??... I have a good black ''c'' which you pull ( this don't sound good but you get the idea ...do you ) just cable is r/s ..have cash waiting cheers davo
- Glenn
- Contact:
Re: CHOKE CABLE
there used to be, maybe still, universal Choke cables available from Auto stores, if all else fails, DaveBULLITT wrote:hi I am chasing a choke cable for the 90 anyone got spares ??... I have a good black ''c'' which you pull ( this don't sound good but you get the idea ...do you ) just cable is r/s ..have cash waiting cheers davo
- yellowperil
- Car(s): 1970 Bellett, 1968 Bellett, Triumph Stag, 1940 Traction Avant, T Ford 1938 Pontiac plus the usual modern stuff
Re: CHOKE CABLE
Glenn is correct, I had to replace the choke cable in the yellow peril some time ago and found one at either Repco or Bursons ( I can't remember which as I find lots of universal parts at both).
It is branded as Bonnet release/ choke cable and you cut it to the desired length. the only problem was that it comes with the cable attached to a standard black knob, not the one with the "C" in the middle. Cheap as chips, around $20 from memory., threaded in nicely and was long enough to give a nice wide loop for easy operation. Piccies attached
YP
YP
- Attachments
- Choke cable2.jpg (221.49 KiB) Viewed 18535 times
- choke cable1.jpg (213.42 KiB) Viewed 18535 times
- Glenn
- Contact:
Re: CHOKE CABLE
for a more 'original' under bonnet look, buy some black heat shrink tubing from Jaycar or Altronics and shrink it over the exposed outer, once the length is worked out.yellowperil wrote:Glenn is correct, I had to replace the choke cable in the yellow peril some time ago and found one at either Repco or Bursons ( I can't remember which as I find lots of universal parts at both).
YP
Re: CHOKE CABLE
thanks guys got a brand new one from Caloundra it has the original 'c 'on it great it looks as the old one ..im stoked $20 cheers davo
- Glenn
- Contact:
Re: CHOKE CABLE
good work, Dave.... keep chipping away.....BULLITT wrote:thanks guys got a brand new one from Caloundra it has the original 'c 'on it great it looks as the old one ..im stoked $20 cheers davo
- Farmer
Re: CHOKE CABLE
Good result mate,
cheers, Matt.
cheers, Matt.
