69 Deluxe Sedan
Chris
Re: 69 Deluxe Sedan
Post by Chris »
Thanks, I have news...
Got the bonnet out of the shed to fix and got the flat tyre off the the front... I really should have fixed that went it went flat... Think the side walls are stuffed.... But then again I think the tyres are 20 yrs old... So should be replaced...
Little bit at a time but... Work has started again on it...
Cheers Chris
Chris
Re: 69 Deluxe Sedan
Post by Chris »
Having the wheel off means I can take a good picture of the front brakes, XF discs and RX7 series 4 calipers.
Re: 69 Deluxe Sedan
Post by BULLITT »
....smick............
Re: 69 Deluxe Sedan
Chris wrote:Having the wheel off means I can take a good picture of the front brakes, XF discs and RX7 series 4 calipers.
that should stop it !
I see re-drilled disks..... not allowed here in Vic.. Is it ok up in NT ?
Re: 69 Deluxe Sedan
Post by BULLITT »
fussy bastards in Victoria in qld all you need is a lead weight and a rope...ha ha
Re: 69 Deluxe Sedan
BULLITT wrote:fussy bastards in Victoria in qld all you need is a lead weight and a rope...ha ha
I thought you just dragged your feet on the road up there Dave..... out thru a rusty floor ;)
Re: 69 Deluxe Sedan
Post by BULLITT »
very goog I like it glenn ...
Re: 69 Deluxe Sedan
Post by Farmer »
They'd have to take a wheel off to notice. Not too many places would do that in newsouth!
Looks pretty sound, and a fair improvement on what is required.
Chris
Re: 69 Deluxe Sedan
Post by Chris »
I um'd and R'd over getting blanks drilled... Just wanted to get the setup all done before I went to that expense...
Wheel fixed so should be able to pull it out of the shed this weekend... About time it's been a while... Looking a bit dusty at the moment... Binet goes tomorrow to the boys at Delta to get sorted.
Slowly working on the exhaust down pipe...
Cheers Chris
flying
Re: 69 Deluxe Sedan
Post by flying »
Chris
Looks great
Hopefully see you for Jap Day in March?
Dave mentioned that the Bellett's may get the centre spot the more the merrier.
Flying
oz_toffa
Re: 69 Deluxe Sedan
Post by oz_toffa »
keep it going chris, along with the photos please...
we re all lovin watching the progress and AJP is on the way.
Chris
Re: 69 Deluxe Sedan
Post by Chris »
Hi,
Slowly but surely the exhaust is happening... :-) AAA Exhausts have been awesome in helping out with tacking the bends as I bring them in. Here are a couple of pictures so far.... Still a bit to go though.
Re: 69 Deluxe Sedan
VERY nice work. Not a lot of space under a Bellett for bigger pipes, mufflers etc.
oz_toffa
Re: 69 Deluxe Sedan
Post by oz_toffa »
Chris, that exhaust is lookin just superb, comin along really well!
keep it going
Chris
Re: 69 Deluxe Sedan
Post by Chris »
A long time ago, I got the wrong light mount, blasted and painted... just wondering if someone may have the right ones...
Re: 69 Deluxe Sedan
Chris wrote:A long time ago, I got the wrong light mount, blasted and painted... just wondering if someone may have the right ones...
Is the picture the one you want ?
Chris
Re: 69 Deluxe Sedan
Post by Chris »
I threw the ones that were on the car away, think there from a PR90 I need some from a PR91....
Re: 69 Deluxe Sedan
Post by Farmer »
Hello Chris.
Knowing which ones you need is a bit difficult. I have some here of various types. PR90 is early GT single headlight. PR91 is single as well until '68 1/2 where they changed to strip taillights and twin headlight. Sedans changed with grille changes. If you post a pic of the grille and light surrounds you intend using that will help identify the ones you want.
I'll help if possible.
Re: 69 Deluxe Sedan
Post by PR91 »
The ones you have are early (teardrop taillight) PR20 sedan. The location of the surround mounts is obvious.
You need the late PR20 mounts that have the surround mounts between the lights themselves.
Chris
Re: 69 Deluxe Sedan
Post by Chris »
Hi, here is a pic of the original grill I want to use, just would like to st least try to get a set of the headlight mounts, really wish I’d looked but 20 yrs ago when I took the thing off... I really didn’t think... twin lights... twin lights... should be the same...
