front shocker
claws
front shocker
Post by claws »
Can someone confirm that front shocker for bellett sedan are Holden HR
PR95
Re: front shocker
Post by PR95 »
Yes
claws
Re: front shocker
Post by claws »
Re: front shocker
Post by Farmer »
Bellett front and rear are the same, and match HT/TK/HG (68 - 70) FRONT. For standard height.
Just one thing, some brands have thicker housings than others. If you can, take a standard one with you to match up, otherwise you might have to grind the hole in the wisbone a little wider to get it through. KYB should go tnrough. Back in the day, there were 2 different shocks, one for 6 cyls and one for V8s. I bought the 6 ones as the V8 ones were too hard.
flying
Re: front shocker
Post by flying »
oz_toffa
Re: front shocker
Post by oz_toffa »
wow that is not real cheap.
Pedders do a comfort gas shock for about $90 each.
ride quite nicely and being gas dampened, perform well too.
Mr Flliiibbbllleeessss may be able to steer you in the right direction.....
