Drum brake stub dimension
RobSA
Post by RobSA »
I have seen one fuzzy picture of this and i can't read the dimensions.
What are the bolt spacings on the drum brake stub axles.
Im trying to set up a 5 stud conversion.
Re: Drum brake stub dimension
Post by BULLITT »
SO HAVE YOU STILL GOT BELLA ???
RobSA
Post by RobSA »
For the moment.
RobSA wrote:I have seen one fuzzy picture of this and i can't read the dimensions.
I assume you want the dimensions of the 4 holes in the stub axle casting:-
pretty sure this is a drum braked stub axle. Actually, as far as I am aware, they are all the same anyway?
I drew this up yonks ago for a TP Magna caliper i think it was. But you should be able to get the dimensions of the bolts holes from it for the axle itself.
The 'square' section is 95mm wide by 100 high.
Bellett stub dimensions.jpg (67.67 KiB) Viewed 37461 times
RobSA
Post by RobSA »
Many thanks Glenn, that's the one.
:D
RobSA wrote:Many thanks Glenn, that's the one.
:D
keep us posted on your progress
RobSA
Post by RobSA »
Okay, so i have Toyota, Mazda and Nissan caliper mounting dimensions.
Can I find bloody Commodore dimensions anyone would think its a big secret. Sheesh.
Oh well I keep looking, scheming and planing.
Toyota calipers are looking good at the moment due to their cheapness.
Nissan would be ideal if the hubs fitted but since I can't lay my hands on any at the moment it will have to wait.
Have a good night everyone.
:D
RobSA
Post by RobSA »
Things are looking positive.
Might have to do some machining of some hubs to fit bearings.
Hopefully once a definite check has been made of stub diameters for bearing IDs then the hubs measured to ensure sufficient material to allow machining then off to the workshop.
Soon to have 5 stud Ford pattern front disc brakes :D
I hope ;)
RobSA wrote:Things are looking positive.
I hope ;)
any particular reason to convert to 5 stud? Machining anything off the stub axle is not good idea.
RobSA
Post by RobSA »
No machining of stub axles, machining of hubs.
Want Ford pattern on the front to match the rear.
RobSA wrote:No machining of stub axles, machining of hubs.
ah...... understood. :)
but how did you do the rear axles?
Post by PR91 »
U use Ford axles....
PR91 wrote:U use Ford axles....
do they fit or have to be shortened/re-splined etc ? Just curious
Post by PR91 »
U have to go the whole 9 yards.
Or maybe just "9 inches".........
RobSA
Post by RobSA »
Though it may well be possible to drill extra stud holes to create the correct pattern on the rear axles.
I'm going the whole 9 yards.
Cheers Rob
