nastys found in oil filter
sdoubleb
Car(s): 67 bellett
Post by sdoubleb »
Found this inside oil filter on the deluxe any ideas where it's come from? Gudgeon pin clip?
sdoubleb
Car(s): 67 bellett
Re: nastys found in oil filter
Post by sdoubleb »
Or second thoughts does it hold the spring an washer in place on the oil filter bolt?
Post by gt orphanage »
Ii will be out of your filter assy.
sdoubleb
Car(s): 67 bellett
Post by sdoubleb »
Yep jumped the gun an panicked. Took Betty's off to check. Looks like it was never put on correctly as the spring an washers dropped straight off when I undone it. Now just need to hunt down some new filters
rod
Post by rod »
Clip no 39
