What engine does this gasket kit suit??
Anthiron
Post by Anthiron »
I have this NOS gasket kit I picked up a long while ago. It is labelled ISUZU 98851-21800 and suits a side flow motor.
At the time I thought it was going to fit my G161 however the inlet/exhaust gasket is all off. (The motor in my LUV has square exhaust ports and round inlet ports which is the oppisite in this kit)
I haven't had any luck searching the part number on google but I was wondering if anyone on here may know.
Nick
Asroc66
Re: What engine does this gasket kit suit??
Post by Asroc66 »
Looks like for
G160SS OHC
Asroc66 wrote:Looks like for
G160SS OHC
yes i have a set for the G180ss and looks very similar except for head gasket size of course.
Anthiron
Post by Anthiron »
Any use to anyone?
Asroc66
Post by Asroc66 »
Keep the rope seals
Front and rear rubber sump seals
Sump gaskets
Timing cover front main seal
For you rebuild
Asroc66
Post by Asroc66 »
Hi
Check these Pistons out
eBay item no.271941108035
Also oil pump
EBay item no. 272054716902
Pretty sure this will fit
But it is listed for the 1800ss motor
Anthiron
Post by Anthiron »
Thanks James,
I have those Pistons saved in my watch list, might wait to see what mine are like first.
Managed to find crank bearings, rod bearings, cam bearings (hope these are the right ones), timing chain, std rings and already have a conversion gasket set as well as what can be borrowed from the above. So almost have everything I need on the way I think.
There is also a guy in my local who trades as "gem wreck" so if I need rods and Pistons I'll try him first.
Asroc66 wrote:Hi
Also oil pump
edited
