Screamin' Squirrel II
Re: Screamin' Squirrel II
..............Tapin' The Skin Back Down..............
- Attachments
- --Bellett-Boot-Rust-Repair--14.JPG (2.49 MiB) Viewed 54233 times
Ted Freeman
- Attachments
- --Bellett-Boot-Rust-Repair--15.JPG (2.48 MiB) Viewed 54233 times
Ted Freeman
................Dummy Fit Of The Replacement Section To Be Welded In................
- Attachments
- --Bellett-Boot-Rust-Repair--16.JPG (2.4 MiB) Viewed 54232 times
Ted Freeman
.................I Really Enjoy The Replacement Panel Side Of Things.................
- Attachments
- --Bellett-Boot-Rust-Repair--17.JPG (2.45 MiB) Viewed 54233 times
Ted Freeman
- yellowperil
- Car(s): 1970 Bellett, 1968 Bellett, Triumph Stag, 1940 Traction Avant, T Ford 1938 Pontiac plus the usual modern stuff
Hey Teditor
That's some serious panel work there. Very time consuming stuff!!
I'll bet it'll come up looking real good.
YP
YP
- Glenn
- Contact:
you might consider treating the inside of the panels to 'kill' or Neutralize that rust.
In the past I have used a Mollasses bath but a good auto paint shop might advise what to use.
.Before Welding In The Replacement Section I Had To Clean Things Up Within (Not Easy) I Seem To Cause More Damage Then Original Burning Out The Wafer Rust Sections Until The Metals Fuse & By The Time It's Painted I Hope To Have No Sign Of Any Rust Repair's.
- Attachments
- --Bellett-Boot-Corner-Repair--1.JPG (2.99 MiB) Viewed 54178 times
Ted Freeman
..The New Section Welded In..
- Attachments
- --Bellett-Boot-Corner-Repair--2.JPG (2.09 MiB) Viewed 54178 times
Ted Freeman
...Dad & I Bought A Nibbler That Goes With Any Drill, The Metal Will Bend While Being Cut With The Nibbler & Also When Welding, So Alignment Is Needed, A Simple Metal Working Dolly & Hammer Will Tap Things Straight Again...
- Attachments
- --Bellett-Boot-Corner-Repair--3.JPG (2.46 MiB) Viewed 54179 times
Ted Freeman
....Grind It All Back & Hay Presto, Instant Panel Replacement....
- Attachments
- --Bellett-Boot-Corner-Repair--4.JPG (2.55 MiB) Viewed 54179 times
Ted Freeman
- Farmer
That is pretty sweet, fellas. A lot if work, but a nice result.
Enjoying the updates, thanks.
I'm getting it easy, my main involvement has been dismantling the car, Michael is doing all the body work, self teaching as he goes, not bad for someone who had never held a welder up to about two weeks ago, ambition and determination will get the project done, hope to eventually get involved in some of the club events.
Ted.
Ted.
Ted Freeman
.Dad & I Needed To Clean Out The Air-Compressor As I Put The Wrong Oil In It & Dad Had Not Released The Valve On The Bottom Of The Tank In 15 Years (It Was Quite Interesting To Say The Least).
- Attachments
- Bellett-1.JPG (2.58 MiB) Viewed 54115 times
Ted Freeman
..Dad Is Working On The Back Left Door As It Will Be Next In-Line For Restoration..
- Attachments
- Bellett-2.JPG (2.77 MiB) Viewed 54116 times
Ted Freeman
...There Is So Much Crap Within, But Justice Will Be Done...
- Attachments
- Bellett-3.JPG (2.85 MiB) Viewed 54116 times
Ted Freeman
....Some Back-Trackin' Here As I Aim To Fix The Rust....
- Attachments
- Bellett-4.JPG (2.26 MiB) Viewed 54115 times
Ted Freeman
.....Not Much Rust Here.....
- Attachments
- Bellett-5.JPG (2.92 MiB) Viewed 54115 times
Ted Freeman
......The Other Side......
- Attachments
- Bellett-6.JPG (2.11 MiB) Viewed 54115 times
Ted Freeman
.......Nor' Much Rust Here Either Yet There Is A Bulge Between The Inner Skin & The Outer Skin Where The Rust Is, The Rust Is Minor On The Visible Sides Of The Skin Yet The Two Inner Hidden Sides Will Be Whats Badly Rusted Thus The Bulge From Within, So I Am Thinking About Cutting The Lot Out & Replacing It With 2x 1mm Replacement Sections About The Size Of My Palm.......
- Attachments
- Bellett-7.JPG (2.32 MiB) Viewed 54115 times
Ted Freeman
.I Mark Out Where To Cut & I Also Stick Within The Line When Cutting.
- Attachments
- -Bellett-Rust-Repair--1.JPG (2.16 MiB) Viewed 54101 times
Ted Freeman
