Bellett Sports 2000GTSS
Gunna
This is the 2 door spare sports project.
The name 2000GTSS comes from:
2000GT (the standard GT Belletts are badged 1600GT)
S (sports model)
The second S (the spare sports that Glenn called it).
We were going to add a small "i" to indicate fuel injection but the name is long enough already.
Picked up from Victoria in Feburary 2016 from Glenn P
First step is stripping for sandblasting.
Edit:
The plan is to fit the G200W 2 litre twin cam motor and 5 speed gearbox in that Glenn supplied with the car. The motor is in surprisingly complete condition.
I have a Motec M4 with opened logging and lambda, and a LCD dash. The plan is to fit that as well. The gps will give me speedo and other usefull (and useless) info. But more importantly I will be able to select up to 4 different running program's for various conditions, such as;
Highway economy
Learner mode
Sports mode
400 metres
Methanol tune
Low grade fuel tune,
And any other you can really think of.
S (sports model)
Edit:
Highway economy
Learner mode
Sports mode
400 metres
Methanol tune
- Attachments
- Lots of ugly surface rust.
- image.jpg (2.39 MiB) Viewed 45244 times
Gunna
Re: Bellett Sports 2000GTSS
Thx Glenn, I was worried about them
- Attachments
- Lego tail lights.
- image.jpg (2.2 MiB) Viewed 45207 times
Gunna
Carbies might be missing but the manifold is there. Yahoo!!!
- Attachments
- image.jpg (2.32 MiB) Viewed 45207 times
Gunna
And what a dash!! In k's.
- Attachments
- image.jpg (1.71 MiB) Viewed 45207 times
Gunna
And in all of the bits was;
- Attachments
- image.jpg (3.14 MiB) Viewed 45206 times
- Glenn
- Contact:
the other tail light surround should be there also Dean ??Gunna wrote:Thx Glenn, I was worried about them
Gunna
And even a flare hidden up under the steering wheel rhs
- Attachments
- image.jpg (1.7 MiB) Viewed 45205 times
Gunna
Nothing so far but I'll keep digging.Glenn wrote:the other tail light surround should be there also Dean ??Gunna wrote:Thx Glenn, I was worried about them
Removing Fuel tank with holes - rusted bolt heads- 9 inch grinder
- Attachments
- image.jpg (1.95 MiB) Viewed 45199 times
Gunna
A small pile of 45 year old rust. Rhsr quarter.
- Attachments
- image.jpg (2.65 MiB) Viewed 45199 times
- Glenn
- Contact:
carefull with the tank, its the rare 46 litre one. (rare here that is)Gunna wrote:Nothing so far but I'll keep digging.Glenn wrote:the other tail light surround should be there also Dean ??Gunna wrote:Thx Glenn, I was worried about them
I may have another surround for the lights if you cant find one in there. I never opened up a lot of the stuff in the car!
whats that badge ??
- Glenn
- Contact:
have a flare in mine also. Must be compulsory in Ja. Goodness knows if they actually work.Gunna wrote:And even a flare hidden up under the steering wheel rhs
Japanese yen $1 ????
- Glenn
- Contact:
not worth much then Dean !BULLITT wrote:Japanese yen $1 ????
Gunna
It came with a sports bellett,,,,,,,priceless.Glenn wrote:not worth much then Dean !BULLITT wrote:Japanese yen $1 ????
Gunna
I've heard about that 46ltr tank from somewhere. It's got some nasty rust holes in it and the drain plug has been pushed up. But if it's rare it's fixable. I was going to junk it as I had been given another standard tank from Peter A.Glenn wrote:Gunna wrote:carefull with the tank, its the rare 46 litre one. (rare here that is)Glenn wrote:
whats that badge ??
Like you, I haven't dug thru everything yet but it is in one space. I'll ferret around once the shell is off to the sandblaster.
- Glenn
- Contact:
Like you, I haven't dug thru everything yet but it is in one space. I'll ferret around once the shell is off to the sandblaster.[/quote]
the 46 Litre tank sits below the bottom edge of the rear valance panel by about 40mm . Std tank is not visible when viewed from rear
Extra 6 litres is well worthwhile
Gunna
the 46 Litre tank sits below the bottom edge of the rear valance panel by about 40mm . Std tank is not visible when viewed from rearGlenn wrote:I've heard about that 46ltr tank from somewhere. It's got some nasty rust holes in it and the drain plug has been pushed up. But if it's rare it's fixable. I was going to junk it as I had been given another standard tank from Peter A.
Extra 6 litres is well worthwhile[/quote]
- Attachments
- Pushed in drain plug.
- image.jpg (2.57 MiB) Viewed 45131 times
- Rust in the 46 litre fuel tank.
- image.jpg (2.86 MiB) Viewed 45131 times
- Another dent from the friendly transport people somewhere along its trip from japan.
- image.jpg (3.11 MiB) Viewed 45131 times
Gunna
Front guards, boot, bonnet & doors off.
Photo includes mad 11 year old with supposedly sore throat and couldn't go to school today.
- Attachments
- Doors, guards, bonnet and boot off. 09/04/164
- image.jpg (2.86 MiB) Viewed 45132 times
Gunna
And this is why we strip them down.
- Attachments
- Lhs lower door pillar rust.
- image.jpg (1.88 MiB) Viewed 45132 times
borer in the usual place ...plate time ??
