Diff info wanted HELP
Re: Diff info wanted HELP
Hi Glenn
Hope to see you and the car there
I think we are all in a last minute rush to get there
Hope everything goes well
Cheers Flying
Cheers Flying
3 down, 2 to go here.flying wrote:Hi Glenn
Cheers Flying
- Glenn
- Contact:
? taking 5 ?PR91 wrote:3 down, 2 to go here.flying wrote:Hi Glenn
Cheers Flying
- Glenn
- Contact:
Got the reco'd diff back today, fitted with the late model shafts and new Uni joints. Much bigger Uni than early cars and grease nipple easy to get at also!Gunna wrote:So your out of trouble now?
- Attachments
- Uni-joint_NEW_grease_nipple location.JPG (101.45 KiB) Viewed 43643 times
Gunna
Glenn wrote:Got the reco'd diff back today, fitted with the late model shafts and new Uni joints. Much bigger Uni than early cars and grease nipple easy to get at also!Gunna wrote:So your out of trouble now?
Almost time to show off the sport to its brothers and sisters, cousins, nieces, nephews, ,,,,,,,
- Glenn
- Contact:
yes it's getting closer by the day.Gunna wrote:Glenn wrote:Got the reco'd diff back today, fitted with the late model shafts and new Uni joints. Much bigger Uni than early cars and grease nipple easy to get at also!Gunna wrote:So your out of trouble now?![]()
Don't expect to see any show car though. The Sport is very original, right down to shrunken original carpets and even exhaust mufflers.
Well done Glenn, see you on the weekend then.
- Glenn
- Contact:
Thanks Stephen.BELLETT69 wrote:Well done Glenn, see you on the weekend then.
Same time?
- Glenn
- Contact:
Same time?
Yep Glenn at this stage we shall say same time on Sunday, if that works with you.
- Glenn
- Contact:
Thats fine Stephen, any time in afternoon will be ok.BELLETT69 wrote:Yep Glenn at this stage we shall say same time on Sunday, if that works with you.
Gunna
So the sport had gtr wheels, gtr sized unijoints.
Does it come with a gtr limited slip diff? Glen< did old mate diff repairer look inside the old diff?
How can you find out (other than a burnout on a gravel road
- Glenn
- Contact:
HI Dean, the diff out of the car is currently in pieces for a quick look see and put back together, sorry no LSD but I was hoping there would be !!Gunna wrote:So the sport had gtr wheels, gtr sized unijoints.
How can you find out (other than a burnout on a gravel road) ?
Notice there is no castellated nut on the the shaft, the cause of all the problems.
- Attachments
- 1972 sPORT-dIFF_2.jpg (103.69 KiB) Viewed 43589 times
- 1972 sPORT-dIFF_3.jpg (53.91 KiB) Viewed 43589 times
- 1972 sPORT-dIFF_1.jpg (110.97 KiB) Viewed 43589 times
- Glenn
- Contact:
Well, the Diff is now back in the car.
A huge thanks to Stephen for helping me do this job on the Sport. Without his help it would have been impossible. WE had a few problems getting it back in, but suceded in the end.
Only have the exhaust system to fit back up, perhaps today and its done. Plenty of smaller jobs to do still.
- Glenn
- Contact:
Exhaust back in, a quick drive around the block, sounds great..... ie no noise
GerryBellettGT
- Car(s): Bellett GT,
Very interesting read,glad you got the winning result,great to see bellett enthusiasts willing to lend a hand and share their knowledge,Gerry
- Stickman
- Contact:
Awesome!!!
And just in the nik of time..... will see you in Albury then Glenn???
- Glenn
- Contact:
yes a great outcome with the help of Steve. I wasn't sure if posting all the 'details' was a good idea, so glad you liked the ramblings.GerryBellettGT wrote:Very interesting read,glad you got the winning result,great to see bellett enthusiasts willing to lend a hand and share their knowledge,Gerry
- Glenn
- Contact:
I'm booked in to the Motel so thats a good sign.Stickman wrote:Awesome!!!
The Sport does need some work on it as its more or less as I got it apart from the rust repairs covered on here. But at this stage it should be at Albury.
- Farmer
That is great! I finally get to see it in the metal.Glenn wrote:I'm booked in to the Motel so thats a good sign.Stickman wrote:Awesome!!!
And just in the nik of time..... will see you in Albury then Glenn???Need to do a bit of a shakedown in the car too.
